Powering the parallax servo control (PSC)
adda
I'm running a BOE on a 9V/300ma and have a PSC connected.· I noticed in the instructions for the PSC that a separate power source is required for the servos running on the PSC.· Can I·share power from·the 9V at the source and run power to the BOE and PSC servos?·(I.e., I would like to·have one power supply and run separate lines from the single power source to the BOE and PSC servos).· ·I'm running 8 standard servo (Futaba) - is the 9V too much?
Thanks.
Thanks.
Not only is 9V typically too high for servos, but adapter is most likely unregulated, which means the voltage will likely be much higher. Besides that sudden current draw from the servos may cause dips or other problems in the supply. Take care.
Dave
Dave Andreae
Parallax Tech Support·
Best regards.
http://www.parallax.com/detail.asp?product_id=750-00009
Dave
Dave Andreae
http://www.mouser.com/search/ProductDetail.aspx?R=L7806CVvirtualkey51120000virtualkey511-L7806CV
The real trick here is to NOT hook up a ground wire to the 5v/gnd/signal side of the PSC -- only the serial signal line and the +5v supply one side, and the beefy 6v and motor ground on the other (the PSC's -Vin and logic GNDs are connected on the board). Otherwise you get a ground loop. A setup like this would work with an external AC-to-DC supply or a battery, etc., presuming you are not overburdening the regulators.
Here's the discussion when I worked this out with the help of the forum members: http://forums.parallax.com/showthread.php?p=610598
I would also add that you can use 5v regulators for the servos as well. Just remember your heat-sinking (and it doesn't hurt to measure total current going into the Vin of the PSC before building your power supply circuit so that you know you won't cause regular shutdowns on your regulator).
Chris was correct. I fried 2 servos. (Please don't ask why one servo was not enough). Voltage regulation is needed if using an AC/DC power source.
Would someone please elaborate for adda (and me; I could use more lecture on the subject) concerning tieing the grounds of separate power supplies together?
adda, I commonly run my Stamp/BOE or Stamp/PDB with the proper wall transformer driving the Stamp/BOE or Stamp/PDB·and my motors or servos driven with a regulated variable DC power supply. I tie the ground of the regulated DC power supply to the ground of the BOE.
The only thing I have fried in my entire (short) microcontroller career is an LED. It didn't really FRY, it went "pop" (lower case). Actually, it was kind of neat. I might do it again.
--Bill
You are what you write.
