SX28 Output Pin state when placed in sleep mode?
When the the SX28 is put into sleep mode do the pins assigned as outputs hold there present state·or are they made tri-state?
Thanks!
David.
Thanks!
David.
They hold their last state.
Bean.
They do hold their state during a sleep cycle, but upon wakeup, they can loose
their state.
If you detect the source of the SX reset (from interrupt, or WDT, etc), and try
to resume your code you can get into trouble. Don't count on the output pins
being in the states you left them in after a wake up.
Try a simple program that uses the WDT, a resistor and an LED.
Set the WDT to wake the chip up every second or so, and determine
the source of the reset. If the reset was the WDT, then read the
state of the·output, and toggle the·output pin (with LED and resistor on it),
and put the SX to sleep. Let the program run.
What you would expect to get would be a 50% duty cycle square wave
flashing the LED·on the output pin, but won't happen.·At least I couldn't
get it to happen on my program. What happens is upon reset, the RA/B/C
Data isn't changed, but the direction registers are forced to inputs...
...and I think that's where the problem is.
Anway, have a look at http://www.parallax.com/dl/appnt/sx/An18Reset.pdf
on page·3 there is a table showing what resets do to each respective
register in the SX. It's the direction registers getting changed that can bite
you.
The workaround to this is to copy your output to registers, and upon wakeup
restore their values. You may still get a glitch on any high outputs, tho...
-Dan
"A saint-like quantity of patience is a help, if this is unavailable, a salty vocabulary works nearly as well." - A. S. Weaver
The doc dkemppai posted seems to have been dated year 2000. Was there a change in design at sometime? Is there anyway I can get the SX48BD to have zero startup delay?
-Matt
