BS2 Select Case problem, via Blue tooth serial conection
Im working on a project where I read in the data from a serial connection and run it into an select case.
For some reason I cant get it to work, keeps telling me “else”
Here is the code, or at least a snippet of it
szData VAR Byte(10) 'Bluetooth serial in
Recive:
'==BT recive== (im using a Bluetooth unit so I display it on my lcd, for debugging purposes
SEROUT lcdpin, baud19200, [noparse][[/noparse]12] 'clear
SEROUT lcdpin, baud19200, [noparse][[/noparse]"Bluetooth Control"]
'serin pin,baud,[noparse][[/noparse]STR var\how many]
SERIN 0,84,[noparse][[/noparse]STR szData\10\CR] ‘<=this is where is store the serial in data
'==Display Input==
SEROUT lcdpin, baud19200, [noparse][[/noparse]STR szData\10] ‘<= I show it here on my lcd no problem
PAUSE 1000 'pause to read
'==Switch Case==
SELECT szData
CASE 0000000001
SEROUT lcdpin, baud19200, [noparse][[/noparse]"Case 0"]
CASE 0 TO 1
SEROUT lcdpin, baud19200, [noparse][[/noparse]"Case 1"]
CASE 1 TO 2
SEROUT lcdpin, baud19200, [noparse][[/noparse]"Case 2"]
CASE ELSE ' invalid command
SEROUT lcdpin, baud19200, [noparse][[/noparse]"Case Else"]
PAUSE 1000 'read time
ENDSELECT
GOTO recive
I really hope there’s a nice quick answer to this..
Thanks!
Rob
Recive:
'==Display Input==
'==Switch Case==
SELECT szData
CASE 0000000001
CASE 0 TO 1
CASE 1 TO 2
ENDSELECT
GOTO recive
Thanks!
Rob
-Martin
StampPlot - GUI and Plotting, and XBee Wireless Adapters
Southern Illinois University Carbondale, Electronic Systems Technologies
As much as it sucks making stupid mistakes, they get solved so simple...
