Microcontroller to e-mail (without computer - via using wireless) — Parallax Forums
ettoetto Posts: 10
edited 2007-02-28 16:03 in BASIC Stamp
I would like to microcontroller(stamp2p40) send e-mail whenever needed. But i don't know what kind of device i need to connect microcontroller and it will connect wireless and send e-mail. There won't be a computer to send e-mail.
I am waiting for your replies.
  • latigerlillylatigerlilly Posts: 114
    edited 2007-02-25 18:08
    Check out the PINK module:
    http://forums.parallax.com/showthread.php?p=631510
    Parallax Info/Manual:
    www.parallax.com/detail.asp?product_id=30013
    Use a wireless access point to connect PINK wirelessly.
    Shameless Plug (please answer my question):
    http://forums.parallax.com/showpost.php?p=0
    Post Edited (latigerlilly) : 2/25/2007 6:18:13 PM GMT
  • ettoetto Posts: 10
    edited 2007-02-25 22:04
    latigerlilly said...
    ·· Thank you for your message.
    · I read the product details but it isn't clear. I will code controllers with computer. But after that point there on't be any computer, system will be alone. But there will be wireless. I think PINK module needs computer to process, is it able to connect wireless without computer and sending e-mail from this module just with wireless connection?
    edited 2007-02-25 22:11
    The PINK module does not need a computer (other than the microcontroller). It is not wireless, so you'll need an ethernet to WiFi adapter.
    edited 2007-02-25 22:18
    Mike Green said...
    Hi Mike,
    Could you explain a bit please?
    Microcontroller + Pink Module and i will connect ethernet to pink module and with ethernet i get WiFi connection, then i am able to send e-mail via WiFi. Am i right? i mean the logics?
    edited 2007-02-25 22:31
    You need Microcontroller + PINK module + WiFi bridge. An example of a WiFi bridge is an SMC-2671W wireless ethernet bridge. Several companies make them.
  • FF Posts: 3
    Try to read about gprs/gsm modems. You can send a SMS to your cell phone instead of send an e-mail.
    I think you can send an SMS to an e-mail, but I'm not sure.
