Suggest a bandpass IC
requirements:
27 to 4200 hz range
Adjustable frequency range something like 1/2 octive on each side of the set point.
I want to play with filtering frequencies for my stage lighting products. I have never used any bandpass or notch filter IC chips before so a little hand holding is necessary to get me on my feet.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
27 to 4200 hz range
If that's too complicated I'm sure that you'll find LM741-based circuits abound.
http://www.swarthmore.edu/NatSci/echeeve1/Ref/FilterBkgrnd/SwitchedCap.html
Looks like the LMF100 is in stock at digikey. So far this looks like exactly what I need. Under 5 bucks as well qty 25
Thanks PJ. Now I wont get much sleep again tonight. Another digikey order but this is cheaper than college tuition.
