SX Pin numbering — Parallax Forums
SX Pin numbering
GAFGAF Posts: 25
edited 2007-03-02 16:34 in General Discussion
Hi,· I have a question on SX/B.· When using the Basic stamp I could use
IN3 to·use pin 3 as an input.· How do I do the same thing in SX/B?
Post Edited By Moderator (Bean (Hitt Consulting)) : 2/22/2007 8:52:37 PM GMT
  • BeanBean Posts: 8,129
    edited 2007-02-22 20:53
    GAF,
    On the SX pins are labeled by their port and position on that port.
    For example: RB.0, RB.7, etc.
    If you wanted to use pin RB.0 as an input you would do:
    INPUT RB.0
    IF RB.0 = 1 THEN
    Bean.
  • JonnyMacJonnyMac Posts: 9,748
    edited 2007-02-22 21:36
    It's a good idea to declare your I/O pins -- this makes the program easier to read and, with outputs, saves you some setup. For example:
    LED     PIN    RC.0 OUTPUT
    This will define pin RC.0 as "LED" and make it an output (saving you the trouble) so your program can do this:
    LED = 1
    Better yet, define constants for on and off like this:
    IsOn    CON    1
    IsOff   CON    0
    ... and then do this:
    LED = IsOn
    See how much easier that is to read/debug -- especially when giving your programs to others?
    edited 2007-02-23 02:50
    JonnyMac,
    That's so well presented -- that even a hard-core "magic number" like me1 can get it.
    Update --
    Post Edited (PJ Allen) : 2/23/2007 2:58:05 AM GMT
  • SailerManSailerMan Posts: 337
    edited 2007-03-02 02:21
    IT doesn't cause an error, but crashes the IDE. Why?· Is there a solution to this?
    DEVICE          SX28, OSCHS1, TURBO, STACKX, OPTIONX, BOR42
    FREQ            50_000_000
    ID  "Sensor"
    Sensor Var Byte(8)
    Sensor(0) Pin RC.3
    Sensor(1) Pin RC.2
    Sensor(2) Pin RC.1
    Sensor(3) Pin RC.0
    Sensor(4) Pin RB.3
    Sensor(5) Pin RB.2
    Sensor(6) Pin RB.1
    Sensor(7) Pin RB.0
    Temp Var Byte
    PROGRAM Start
    Start:
    Main:
    Do
      For Temp=0 to 7
        Pulsout Sensor(Temp),100,25
      Next
      Pause 250
    Loop
    Post Edited (SailerMan) : 3/2/2007 12:14:51 PM GMT
    edited 2007-03-02 02:58
    IT doesn't like the array that you're trying to set up.
    Is this what you're trying to do?
    DEVICE sx28, oschs3, TURBO, STACKX, OPTIONX
    IRC_CAL  IRC_SLOW
    FREQ     50_000_000
    PROGRAM Start
    ID  "Sensor"
    Start:
    Sensor0 Pin RC.3
    Sensor1 Pin RC.2
    Sensor2 Pin RC.1
    Sensor3 Pin RC.0
    Sensor4 Pin RB.3
    Sensor5 Pin RB.2
    Sensor6 Pin RB.1
    Sensor7 Pin RB.0
      Do
      Pause 250
      Loop
    Update -- Forgot to add that this much compiles.· It's disallowing combining an array and Pin Numbering.· I think that you'll need to add input/output after the Pin Number, too [noparse]/noparse]i.e. [i]Sensor Pin RC.3 INPUT[/i
    Post Edited (PJ Allen) : 3/2/2007 3:07:33 AM GMT
    edited 2007-03-02 04:07
    Pin names must conform to label specs: up to 32 characters, must start with an alpha, the only non-alphameric character allowed is underscore. If you inputs are simple digital inputs then there is an easy way to iterate through them as your declarations suggest you want to do.
    edited 2007-03-02 11:38
    SX/B does not support bit arrays.
    I will look into the crashing, it should cause an error.
    Bean.
    Coming soon! Propeller based OSD module www.hittconsulting.com
    edited 2007-03-02 12:11
    Bean,
    Is there a good way to do what I'm trying to do in the above code?
    I need to iterate through non sequential pins.
    Eric
    edited 2007-03-02 14:02
    Eric,
    You can use a bit mask.
    It would be alot easier if you connected all the sensors to one port (either RB or RC).
    Will the order change at runtime ? If not then just change the connections so they are in order.
    Assuming you are using the RB port for all sensors, and the array bitPos holds the bit position of the sensor to pulse, you would do:
    FOR temp = 0 TO 7
    · mask = 1 << bitPos(temp)
    · RB = RB XOR mask ' Invert bit
    · PAUSE 25 ' PULSOUT x, 100, 25 = 25 mSec
    · RB = RB XOR mask ' invert bit
    NEXT
    Bean.
    edited 2007-03-02 14:34
    I was going to put them all on the same port, but the layout and routing of my board was so much easier.
    I guess that I will have to spend some more time re-routing my board and just use Port RB. It seems the most Logical course of action... Thanks for your code snipet.
    Eric
    edited 2007-03-02 15:03
    Eric,
    · If you want to use both RB and RC then you just need to make "mask" a Word variable and use RBC.
    · bitPos() elements can be from 0 (RB.0) to 15 (RC.7)
    FOR temp = 0 TO 7
    · mask = 1 << bitPos(temp) ' mask is a WORD variable
    · RBC = RBC XOR mask ' Invert bit
    · RBC = RBC XOR mask ' invert bit
    NEXT
    · I always optimize my layouts and adjust the software to work. It's much easier to make a software mod, then a hardware mod.
    · The drafting dept as work loves me because I don't show what pin a connection is to on the SX. I just say "It can be connected to any of these pins". It really freaks them out, they are not used to being able to do that. Then I always find lots of ways to simplify the layout after they do it, by using a different pin for something.
    · Just don't forget about I2C pins, they must be in a specific order. I've got them backwards a couple times then the SX/B I2C commands don't work.
    Bean
    Post Edited (Bean (Hitt Consulting)) : 3/2/2007 3:10:16 PM GMT
    edited 2007-03-02 15:53
    It took me a sec, but I see the you're·creating a pulsout with this.
    ·So I should define an Array of Bit Positions.
    What is the Best Way to load the Array with Bit Position info.
    BitPos(0) = %0000_0000_0000_1000
    BitPos(1) = %0000_0000_0000_0100
    BitPos(2) = %0000_0000_0000_0010
    BitPos(3) = %0000_0000_0000_0001
    BitPos(4) = %0000_1000_0000_0000
    BitPos(5) = %0000_0100_0000_0000
    BitPos(6) = %0000_0010_0000_0000
    BitPos(7) = %0000_0001_0000_0000
    Am I thinking of this in the right way? I'd test it but I 'm not at home.
    Eric
    Post Edited (SailerMan) : 3/2/2007 3:59:47 PM GMT
  • Guenther DaubachGuenther Daubach Posts: 1,321
    edited 2007-03-02 16:12
    maybe, this is a bit off-topic here as I'll show examples in ASM here, and not in SX/B...
    In general, I agree with Bean that assigning SX I/O pins to specific signals can be arbirtrary in most cases. Nevertheless, sometimes, it makes software design easier, or more compact when you use specific pins. For example, in a serial receiver code, you will often find the instruction
    movb C, RxD
    where RxD can be any port pin used as serial input. The movb instruction is a compound instruction, i.e. expanded to
    sb RxD
    clrb C
    snb RxD
    setb C
    so it takes four program words, and four clock cycles for execution.
    If you were using RB.7 as RxD input pin, for example, you could move the status of RxD into the C flag with just one instruction:
    mov w, <<RB
    This moves the left-rotated contents of RB into w but also rotates bit 7 of RB into the C flag.
    You can also use RB.0, for example, together with
    mov w, >>RB
    Besides this, keep in mind that only the port B inputs allow for wake-up, and interrupts, and the RA pins can't be configured as Schmitt-Trigger but they have symmetric source/sink characteristics when configured as outputs.
    Greetings from Germany,
    G
    edited 2007-03-02 16:33
    Eric,
    No, you just want to put the bit position VALUE into the array.
    0 to 7 = RB.0 to B.7 ; 8 to 15 = RC.0 to RC.7
    So:
    PUT bitpos, 11, 10, 9, 8, 3, 2, 1, 0
    Bean.
    Gunther,
    That was way over my head but thanks. [noparse]:)[/noparse]
    Bean,
    Great thanks for clarifying that for me.
    ERic
    Post Edited (SailerMan) : 3/2/2007 4:38:52 PM GMT
