Homebuilt propeller board
I built a simple parallax propeller board consisting of a homemade pcb (for the rs232 to usb converter) with a breadboard. I can't get propeller tool to see the prop chip. Windows sees the usb device and virtual com port, but i can't get anything to transmit/receive. I checked the circuit many times, and cannot find any errors or shorts. What may be causing the problem
The fact that your computer acknowledges the USB device is promising, so we know that part of the circuit is good. That leaves the connection to the Propeller, or the Propeller itself is not responding. I assume the Propeller is properly powered, grounded, etc?
We are all eager to help
Brian Meade
"They who dream by day are cognizant of many things which escape those who dream only by night" - Edgar Poe
The mic, audio, video, keyboard, and mouse circuits were removed.
The programmer was modified to use a FT232BM. The circuit in the FT232BM datasheet was used.
Strangely enough, I plugged it in today, and it worked almost perfectly. I tried plugging it in different ports, moving the boards roughly to do an abuse test, and it still worked, the Propeller Tool only failing to find the chip twice.
I'M STUMPED.
