Looking for a DIGIKEY equivalent for the pin header used in the kits.
I would like to get a quantity of the pin headers that are are used in the bread-boards for connection to servos, whiskers,·and the like.
Does anyone have·an equivalent·DIGIKEY part number handy? I am hoping to get a 40 pin stick of pins that can be broken to get combinations of 3,4, or 5 pins.
Doesn't have to be a DIGIKEY part -
Parallax part is:
451-00303
Post Edited (Russ Ferguson) : 2/21/2007 3:31:42 PM GMT
Parallax part is:
451-00303
WM6436-ND
-Martin
StampPlot - GUI and Plotting, and XBee Wireless Adapters
Southern Illinois University Carbondale, Electronic Systems Technologies
The pin "tail" is not as long as the ones·that are sent in·the kits.
The ones from the kit measure:
···················· "Matting length": .260
········ and······ "Tail length":······ .230
I'm guessing that they must be some sort of a "connector" instead of·a "board pin header".
Thanks for pointing me at that spec. The closest in the spec was .280 & .250· or· .235 & .210 (but they are not catalog items as far as I can tell).
http://www.mouser.com/catalog/629/1111.pdf
- Rick
Parallax support suggested this Digi-Key part:
S1022E-36-ND (around $2 a single strip).
Tin pins, Single Row Straight (36 Pins), and around $2 a single strip.
"Matting Length" - Dimension A - .230
"Tail Length" - Dimension B - .230
This Digi-Key part appears to be a reasonable alternative:
929834E-02-36-ND (around $1.80 a single strip).
36P STRT 1 ROW TIN
"Matting Length" - Dimension L - .235
"Tail Length" - Dimension B - .210
The Mouser number for the same manufacture is:
517-834-02-36 (around $1,40 a single strip)
Pin Strip Headers 36P STRT 1 ROW TIN.
"Matting Length" - Dimension A - .235
The .210 “Tail Length” appears to be long enough to slide into·a female (servo type) connector and make a good mechanical connection.
