linear regulator LM1086
Can anyone give me some insight on linear voltage regulators and how much heat they will generate as the output voltage and the input voltage get further apart. I designed a board for the propellar for a project of mine and used a LM1086 giving me an output of 5v but I want to input 24v is this to big of a difference? I did design extra copper on the board as a small heat sink but any idea what kind of temeratures I can expect? is the any kind of drop in solution for a to263 package?
thanks,
Owen
thanks,
Owen
Having said that, Ohm's law applies -- V = IR, and Power P = IV, or P = I^2 * R.
So, if you have 24 volts in, and 5 volts out, that's a voltage drop of 19 volts.
Now, the heat equation. Power is equivalent to Heat, in these cases -- in that P = IV equation, the P terms are 'Watts'. Each linear regulator has a certain heat dissapation it can manage. And you can increase that heat dissapation by adding a 'cooling fin' heat-sink to the device (using a suitable insulating mica wafer, and heat conductive "thermal grease"). If you don't dissapate enough heat, the temperature of the device will rise to the point where a "Thermal Crowbar" will turn off the device -- it's output will go to zero, and the current through it will go to zero, until the device cools down.
A quick look at the LM340-5 device PDF (http://www.national.com/ds/LM/LM340.pdf) on the "Maximum average Power Dissipation" graph, shows that a TO220 form-factor device can dissipate about 2.5 Watts at zero degrees without a heat-sink. With a heat-sink, it can dissipate 5 Watts at room temperature.
For some idea of scale, you can purchase a 5 Watt light bulb -- it's awfully dim, though.
OK, so we have 19 volts, and 5 Watts. P = IV, so 5 = x * 19, so x == 260 mA maximum. And that's IF you put on a good heat-sink.
Without a heat-sink, at room temperature (75 degrees or so) you have maybe 1 Watt of dissipation. 1 == x * 19, x == 52 mA.
Also from the PDF, if you have 1 square inch of copper for the TO263 package, you have a "Theta" of 35. Power dissipation with a Theta of 35 is about 1.5 Watts -- so we're back to 79 mA or so.
The big problem you have here is that huge, 19 volt drop, which then drives the power equation. Some people have handled this with TWO linear regulators, a 7812 and a 7805, which can give you more area for heat dissipation. I believe it's also possible to get a "switching regulator" IC, which avoids the "I'm a variable resistor" problem.
Post Edited (allanlane5) : 2/20/2007 6:46:45 PM GMT
I believe the LM1086 has a fairly large Maximum allowed 'Input to Output potential difference'
See attached doc
but ...
I have many stamp based designs out there with 24v Supply to LM7805CT voltage regulators..
these have a 35v VIN max for the 5v regulator
also see attached Doc
Obviously the higher the VIN the more work the reg has to do - the hotter it will be - I Have used these without a heat sink - but have them attached to the pcb via tab·(TO220) to a good ground plane and some thermal paste - in this config. they get a bit warm - but not HOT. These are available in a variety of package types.
Quattro
'Necessity is the mother of invention'
Post Edited (QuattroRS4) : 2/20/2007 7:01:14 PM GMT
I wish I had asked this before sending off my pcb design to batchbcp. I wanted to be able to provide 500ma from the regulator but it doesn't seem very likely with a 24V input. Does anyone know of a to-263 3pin switching regulator I could use without a pcb re-design? I couldn't find anything on the digikey web site.
thanks
Owen
- Stephen
Quattro
thanks,
Owen
All the other issues cover available form-factors -- I've seen IC form-factor switchers, but not TO263. And it's hard to make a switcher as physically small as a linear regulator.
Sadly, this highlights one of my ongoing issues -- the coolest, best designed circuit board in the world still can't be delivered until the power and enclosure issues are solved. Even though you'd have thought power and enclosure problems were trivial when you began.
Owen,
······· With the examples of regulators given e.g. LM7805CT - while it may be a TO-220 package - it has a 35v max Vin - seriously consider modifying the likes of this to suit the circuit before reording boards - perhaps fit it on a seperate small pcb· - may be an option ?
Quattro
Post Edited (QuattroRS4) : 2/22/2007 3:47:06 AM GMT
most of the power.
To lower Vin to 7.5V @0.5A using 24V input
Rs = (24-7.5)/0.5 = 33 ohm
The power dissipated in Rs @0.5A
Ps = 0.5*0.5*33 = 8.25W
So you need a 33ohm/10W resistor
There will be a ripple at the board Vin that depends on the current fluctuation.
Since line regulation < 0.1% you may, or may not, require an additional
input capacitor.
regards peter
Post Edited (Peter Verkaik) : 2/22/2007 9:32:11 AM GMT
http://www.dimensionengineering.com/DE-SW0XX.htm
- Rick
That is a fair point but I think current o/p is also a consideration from what I gather ...
input voltage to the regulator (7.5V for LM7805) the calculated values are correct.
One does however need to check the maximum power dissipated·by the regulator.
Pr = (24-I*Rs-5)*I = 19*I - Rs*I*I ->parabolic function -> there is a maximum
dPr/dI = 19 - 2*Rs*I = 0 yields I = 19/(2*Rs) for which regulator dissipates maximum power
For Rs=33ohm I=0.288A
So the 5V regulator dissipates (24-0.288*33-5)*0.288=2.73W maximum @I=0.288A
At I=0.4A the regulator dissipates (24-0.4*33-5)*0.4=2.32W
So a heatsink is still required.
If the required load current·is less, then Rs·increases, and regulator power dissipation
decreases.
regards peter
