Protoboad enclosure?
Hey All!
Does anyone know of an enclosure that will work perfectly with the prop protoboard?· I need one that will just fit the protoboard so that my connections can be set up along the edge of the board and can be access via a hole in the enclosure.
I am searching polycase.com but have not found one yet!
Thanks!
Dave
Thanks!
Dave
it is not a perfect fit but it works you just have to trim the standoffs
lets see what this does... KA BOOM (note to self do not cross red and black)
Anyone else have any info?
Thanks!
Dave
Brian Meade
"They who dream by day are cognizant of many things which escape those who dream only by night" - Edgar Poe
The solution is to just pick up a bag of standoffs. Then you can either affix them with screws through the case, or, if that would look bad in your application, superglue them in the appropriate positions inside the case.
That is starting to look like what I need to do. At least on one side of the case. I found some that have the right dimension on one side, but not the other...
Where can I get these standoffs?
Thanks!
Dave
http://www.radioshack.com/product/index.jsp?productId=2102860&cp=&sr=1&origkw=standoff&kw=standoff&parentPage=search
if you want them quickly.
But be warned that that price is a total ripoff - you can buy them from most electronics parts stores for about a nickel each.
Barring that, I would just get some 4-40 machine screws and a handful of washers from your local hardware store, and use them to build appropriate height standoffs.
I found some at sparkfun.com too. Looks like I will be using this option.
Thanks!
Dave
