Propeller Demo board Rev F restarts anytime an Audio Plug is inserted into audi
I have a rev f prop demo board that restarts anytime a 1/8 " TRS plug is inserted into the audio out jack. The same thing happens even when a "fresh" (no connections) plug is inserted. I originally thought that the jack had a "sense" lead and the behavior was normal. I took a look at the schematic which shows only the typical connections (left right and ground), but when examining the board, there are actually 4 pads soldered to the jack. (one maybe just an anchor?) Anyway, is this behavior normal and if so, why ?
If you insert the plug very quickly it occasionally won't restart, also the same results occur when "disconnecting" the plug.
Mark S.
Mark S.
do the insertion.
thanks,
Mark S.
