H48C Accelerometer
Hi, I have a (hopefully) simple question regarding the H48c accelerometer
I execute the code in the sample code for the accelerometer:
But, I find that the range of the difference between axisCount and VrefCount, only ranges only from -455 to 465 (decimal). In other words if I subtract axisCount - VrefCount the result ranges from -455 to 465.
I thought that I would see the full range (total counts = 4096 for a 12-bit A/D Converter) from -2048 to 2047.
Can anybody give me some advice on this?
-Cisco
LOW CS
SHIFTOUT Dio, Clk, MSBFIRST, [noparse][[/noparse]%11\2, VRef\3] ' select vref register
SHIFTIN Dio, Clk, MSBPOST, [noparse][[/noparse]VRefCount\13] ' read ref voltage counts
HIGH CS
PAUSE 1
LOW CS
SHIFTOUT Dio, Clk, MSBFIRST, [noparse][[/noparse]%11\2, Tiltaxis\3] ' select axis
SHIFTIN Dio, Clk, MSBPOST, [noparse][[/noparse]axisCount\13] ' read axis voltage counts
HIGH CS
-Cisco
