Problem with EEPROM (24LC128)
MacGeek117
I've been trying to write/read to an EEPROM with this program, but nothing is working. Does anyone have any suggestions?
RoboGeek
"I reject your reality and subsitute my own!"
Adam Savage, Mythbusters
www.parallax.com
www.goldmine-elec.com
www.expresspcb.com
www.startrek.com
Post Edited (RoboGeek) : 2/17/2007 9:19:52 PM GMT
RoboGeek
www.parallax.com
www.expresspcb.com
www.startrek.com
Bean.
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
RoboGeek
www.parallax.com
www.expresspcb.com
www.startrek.com
Read is %1010001 and write is %10100000
Bean.
RoboGeek
www.parallax.com
www.expresspcb.com
www.startrek.com
Bean
RoboGeek
www.parallax.com
www.expresspcb.com
www.startrek.com
Bean.
RoboGeek
www.parallax.com
www.expresspcb.com
www.startrek.com
I think all of you agree with me that Bean is one of the best "bug detectives" here in the forum. Nevertheless, it would save Bean's and other helpers a lot of time (but also the time of a "problem poster") when you post your problem together with the program code in question, but also a schematic showing the SX and its hardware environment.
Typically, microcontroller applications consist of hardware and software, so it helps a lot giving problem support when both parts can be inspected right away. I'm sure that Bean (or someone else) would have been able to figure out the missing pull-ups right on your first post when you had attached the code and the schematic together with it. Without this, it took some "ping-pong" posts, plus some (very professional) guesswork from Bean to figure out the problem.
Please get me right - this is constructive criticism only, but I think it is a good example for new (and maybe old) forum members how to optimize their requests, and how to get exactly the hint they need to fix a problem.
Greetings from Germany,
G
Your welcome.
And to Guenther's point, I'm reminded of a saying, "A problem well defined is a problem half solved".
The forum member's are good, but the more information you provide the better chance that your problem will be solved.
Bean.
RoboGeek
www.parallax.com
www.expresspcb.com
www.startrek.com
