Windows XP Standby
Newzed
I have a new computer with Windows XP.· I decided to try Standby - clicked on Turn Power Off/Standby.· The computer shut down and the only way I could start it again was to turn the computer on again, where it went thru the reboot process.· Is this the way Standby works?· If so, what's the difference between Standby and just turning your computer off?
Sid
Yesterday is history, tomorrow is a mystery, and today is a gift.
That is why they call it the present.
Don't have VGA?
Newzed@aol.com
Sid
Don't have VGA?
Newzed@aol.com
Paul Baker
Sid
Don't have VGA?
Newzed@aol.com
Jeff
EDIT what options are you selecting?
Sid
Don't have VGA?
Newzed@aol.com
Right click anywhere on screen, pick properties/screen saver/monitor power/hibernate... and see if it is checked...
otherwise you can select "advanced" and how the system responds when power button is pushed momentarily....
Bob
Sid
Don't have VGA?
Newzed@aol.com
Check it....
But what you want is found under advanced selection towrads the bottom;
"When I press the power button" select "standby" on pulldown menu..
Then it will also show on the "Turn off Button" under the "Start" button...
You can also make a desktop "Icon" that does the same thing if clicked on..
Just do a Google for "Desktop standby shortcuts"...
Bob
Post Edited (Robert Kubichek) : 2/18/2007 1:08:31 AM GMT
Sid
Don't have VGA?
Newzed@aol.com
Bob
If you are still having trouble, and when you select "standby" from the "Turn Off My Computer" choices, the machine totally shuts down, and goes through the full boot cycle, and you don't end up where you left things, you may want to check the owners manual or support for your particular hardware.
I think part of what Paul meant by "Properly implemented" is that the hardware has to support "Standby" mode. In some cases, as Kevin indicated, you may need to enable this in the BIOS. This feature was initially intended for Laptops to help save battery time, and I don't know that all "desktop systems" (or even all laptops) support it, or implement it "properly".
John R.
Click here to see my Nomad Build Log
Paul Baker
Post Edited (Paul Baker (Parallax)) : 2/18/2007 5:39:33 AM GMT
Sid
Don't have VGA?
Newzed@aol.com
Management says "User defined".· Suspend mode says "Disabled".
Are these settings correct?· I scrolled down to User Define, pressed Enter and got a little screen that says:
User Define........[noparse][[/noparse] ]
Min Savings........[noparse][[/noparse] ]
Max Savings.......[noparse][[/noparse] ]
Should there be something in the empty brackets?
Sid
Don't have VGA?
Newzed@aol.com
User Define alows you to custom set or tweak all parameters
Min/Max Savings do just what they suggest...
Without any of the boxes checked, it is just like having power managment turned off..
Bob
Sid
Don't have VGA?
Newzed@aol.com
Try Max 1st for a while, and if not satisfied with results then change to Min....
Custom is for fine tuning...
bob
Sid
Don't have VGA?
Newzed@aol.com
each mob maker uses different keys...
Bob
Sid
Don't have VGA?
Newzed@aol.com
I've not seen ENTER used much, but I have seen the following key combinations used:
Single Key TOGGLE (ON/OFF, YES/NO, etc)
space bar
Multiple Key TOGGLE (ON/OFF, YES?NO, etc)
Page Up, Page Down keys
Up Arrow, Down Arrow keys
+ , - keys
My guess is that only one of those will work for you, and the others should be ignored. Often the BIOS System will have a HELP scren which will explain which keys to use for which purpose. Sometime the HELP screen is invoked by a function key; often F1. ESC (escape) will usually cause you to go back to the BIOS menus.
Bruce Bates
Post Edited (Bruce Bates) : 2/18/2007 5:35:28 PM GMT
Sid
Don't have VGA?
Newzed@aol.com
It will have instructions on how to set up the mobs bios...
Can you call your grandson's friend (or have your grandson call his friend) for some assistance?
Without know the specifics of what Mother Board was used (and what BIOS chips) what options, what jumpers, what's supported, what's not, you're (and us) just stabbing in the dark.
John R.
