Reset a Prop via serial command, not reset pin
I have several Props on one serial port, no loop back, just Rx on each. Is there a way to address one specific Prop with a serial command and reboot that entire chip?
Post Edited (originator) : 2/17/2007 5:39:56 PM GMT
There will be no reaction from 2 or 3 as it will not be programmed to react to '1RES'
prop2 is programmed to REBOOT if it receives '2RES' and so on .....
Post Edited (originator) : 2/18/2007 7:16:14 PM GMT
It happens to us all - I usually find when I have a 'massive' problem it is either a) completely destroyed
b) the most simple of things - and experience has shown it is usually the latter !
Quattro
'Necessity is the mother of invention'
