FRAM
Mike (and All)--
Do you have experience using a FRAM device in the Stamp environment? It looks (to me) like you would treat it exactly like an I2C EEPROM.
I read the data sheet on this Ramtron FRAM. Of course, it is a "raw" surface mount device and I would like something I could actually SEE and use in the Stamp environment. Have you done this and do you have advice?
--Bill
ps The FRAM mentioned above is a 256k machine organized in 32k x 8 bit chunks and you can string up to eight of them together . . . as I read the datasheet.
You are what you write.
--Bill
The Ramtron FRAM chip comes (like most stuff these days) only in surface mount packages. You can get "breakout boards" from SparkFun Electronics that will let you make a DIP version with a little soldering and some machined pins. Functionally, they work like a standard 24LC256 (32K x 8) I2C EEPROM except that they write faster and don't wear out. They're designed to be "drop in" replacements. Recently, their website also shows a 24LC512-like version (64K x 8) so they're slowly working up in density/capacity.
Thanks for the info. This sounds like a great "see if I can do it project."
I notice that a lot of folks express concern about soldering surface mount devices. I am somewhat of an amateur engraver and have a GREAT Meji stereoscopic microscope with a ball vise. If I knew what kind of soldering iron and temperature to use, I don't believe soldering would be a problem.
Soldering irons and related hints would certainly be welcome!
--Bill
- Stephen
