Sensor help
I am currently in need of some help... i was wondering how i should go about doing this project... i have a sensor that uses has 2 leads a ground and an output. The sensor outputs a voltage from 0-1 volts and everything inbetween. I was wondering if it was possible to detect the voltages coming out of the sensor without blowing up the bs2?
What kind of sensor is it? Who makes it? Do you have a datasheet?
Bruce Bates
<!--StartFragment -->
