My SX Tech Board Quit working!!!
Hey all,
Could some one help me out...
My SX Tech Bord quit working, It's not the SX chip, or the power supply. I know this because I tried them both in the Brofessional Development Board. I also get power to the board like it should but will not run or program with the SX Key that is also working.
Has this happened to anyone else before?
Any help would be great!!!
Lance Miller
Lance Miller
What happens when you try to program it? If you can report an error message, that will be helpful.
- Sparks
It does nothing different.
It says it has downloaded successfully.
It will also run for a split second and thats when it turns off.
Lance
If you go to Device --> Verify does it verify ok?
Is there anything else connected to the SX Tech board?
What do you mean when you say it “turns off?” I assume the green power LED is still lit. Correct?
What happens if you try to debug and step through the program?
I wish I could be more helpful, but I can only think of questions to ask at the moment.
- Sparks
The green LED is still on...
I will try the Other things you mentioned tomorrow Morning.
Lance
My suggestion is to remove the circuit. I bet there's a short or excessive current draw somewhere. I've had exactly this problem in the past.
A description of what you mean by "turns off" would help.
And, adding a DEBUG statement at the very beginning of your program saying "Running" might help understand whether the program executes anything before "turning off".
PAR
even with the 2200uF capacitor across Vss and Vdd, the two servos may cause an initial load when you power up the board that causes the SX and/or the SX-Key do a reset, or enter into some unknown state. The same is true when the servos start moving. To my experience, it is always better to use a separate 5V regulator for the servos.
What happens when you temporarily disconnecte the sercos? Does the system work in this case?
Greetings from Germany,
G
I removed everything... Still not working.
When I go to Debug it, it just goes to sleep mode.
I Hooked up a new SX chip to the board it worked....Until I turned off the power. Then it is doing the same thing as before.
I'm using the 6-7.5 Vdc power supply, that can with the PDB.
Really confused, is thier a spec sheet for the board. So I could make sure the voltages are all correct?
Lance
After playing around with it alittle bit longer I put another program into it and it worked great!!!
I'm just learning how to use the SX for I have only used the BS2 before.
I will attach my program that is not working...
Thank again for the help,
Lance
You are enabling interrupts, but you don't have an interrupt handler.
Remove this line "OPTION = $88 ' interrupt, no prescaler"
Bean.
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
Thanks TO ALL for the help!!
Lance
In all my assembly code programs, I always place a RETI instruction at address 0 - just in case...
Maybe, a future version of SX/B could generate this instruction in place automatically as long as no other interrupt code is specified in the SX/B source code.
G
