ADC Accuracy
After reviewing AN001 I'm amazed with what the Propeller can do. I want to convert a dc level to digital with 8 bit accuracy and·I see on page 17 of an001 the resolution can be just about any value. What will the accuracy be, ie, vs temp and VDD changes?· Will it be monotonic? I would imagine the change in the digital value with change in VDD would·track well.· That means I could do a ratio of input to VDD and it would eliminate VDD from the equation. I suppose you could correct a DAC output in the same manner.· Has anybody actually measured the performance?
Also, would running without a crystal osc have any effect on accuracy as long as the clk remained stable for the duration of on measurement?
Tom
Tom
The onboard oscillators are accurate enough in the measurment window, however repeatability·is an issue especially with any change in the ambient temperature.
Paul Baker
Post Edited (Paul Baker (Parallax)) : 2/15/2007 10:58:01 PM GMT
Tom
0 to 5 volts,·I get 1.21mv per ADC count.· Reading 0 to 3 volts, I get about .74mv per ADC count.
Sid
Yesterday is history, tomorrow is a mystery, and today is a gift.
That is why they call it the present.
Don't have VGA?
Newzed@aol.com
Paul Baker
Tom
Paul Baker
Tom
In regard to oscillator changes due to temperature.... it has negligible effect. A typical conversion (especially only 8 bits) will be completed in such a short time that the oscillator can be considered stable. Temperature affecting the switching threshold is another story that I have yet to ferret out.
The ratiometric concept definitely works.
I'm presently pursuing a 16 bit model using an SX (quite noisy), and we'll see how it goes.... so far the signs are encouraging.
Cheers
Peter (pjv)
