draw per pin
I am driving an optoisolator with a bs2sx pin - it draws 15ma. This optoisolator then drives a relay.
Is the 15ma ok? I understand the limit is 30ma per pin, 60ma total, but is 15ma continuous a good idea or should I use a transistor to drive the optoisolator?
Carlos Ferguson
Carlos Ferguson
Properly designed, you should be able to drive ONE pin at 15 mA. The question then becomes, what else is your chip doing?
A Darlington Array would probably be a good idea.
Carlos
ps thanks for the fast reply!
Carlos
I have included a pdf on a 'Pvdz172' photovoltaic (pvdz172.pdf)- which is an opto Isolated ssr.It uses MOSFET switch stage ,incorporates a reversed biased diode (ideal for inductive loads) can switch up to 60VDC and can drive up to a 1.5Amp load. I have used it many times with basic stamps.
I also drew a quick application sample schematic for you to show connection (jcferguson_sample.pdf). You will see in the schematic I have used a 4.7K pull down resistor (R1) and a series resistor 1.5K to device. The device requires 10mA to switch.
Quattro
Carlos
