Is my propeller dead?
Hi.
I have a propeller chip installed on a propSTICK, and last nigth i was trying to test the propeller, hence get a led blinking. It worked perfectly, but today the Propeller tool tell me "No Propeller chip found on any COM port".
I have connected a +9V DC to the Vin on the propSTICK, just like last nigth. When meassuring over the Gnd and 3.3V pins on the propeller the result i 3.25v, so it looks okay.
But is there anyother way i can test the propSTIC/propeller setup? Or should i just assume that my propeller chip is dead, (and not the propSTICK) and buy a new Propeller?
I have only installed the Propeller tool and then used the F7 shortcut.
With an amplitude of 2v peak-to-peak.
The XO pin on the other hand, give an far-from perfect sinus curve.
Its the okay for the chip?
Can I somehow test the RS232 interface of the propSTICK?
As for the 2VPP I am not sure if that is bad or not. I checked mine some time back and think it was closer to 3PP, maybe someone else can clarify if that is within specs?
Post Edited (bambino) : 2/15/2007 2:40:55 PM GMT
Cheers,
Simon
BTW: I type as I'm thinking, so please don't take any offense at my writing style
www.norfolkhelicopterclub.co.uk
You'll always have as many take-offs as landings, the trick is to be sure you can take-off again ;-)
Pressing the propeller into the socket again didnt change anything.
Regarding measuring the Rin on the MAX3232 chip, what would the peak-to-peak voltage be, and how fast should the periodetime be when pressing "U" in hyperterimal?
Although the Prop should read it if the High is 2.5V or greater.
For a Baud of 115200 1/x gives 8us.
Post Edited (bambino) : 2/15/2007 3:54:43 PM GMT
Good Luck,
I have attached a 9volts Duracell battery to the Vin + Gnd on the propSTICK.
Thanks for your help bambino, tomorrow I will try with my scope and see if there is a signal from the RS232 interface to the MAX3232 chip.
I have just tried with another new 9v battery and no luck. Tomorrow i kan try with an real PSU, to see if it changes anything.
Then ... mostly as a way of venting my·frustration ... I just tried a series of·repeated pressing of the reset button on the PropStickUSB and pressing F7 (Identify) on the PC and somehow it finally woke up and has been working perfectly ever since.
Go figure ...
Stan Dobrowski
Got the new chip today, everything worked like a charm. So im guessing that the old chip some how died.
Back to the fun stuff, coding.
