GP2D12 GPIO14 Basic Stamp
Hello everybody,
does anyone have any idea please if it is possible to program with PBASIC a GP2D12 IR Detector connected to a BS2PX through GPIO14 (ADC pin)?
Thank you
Thank you
If you check the GPIO14 documentation you will see you have a number of choices for using the ADCs. In my case, I chose to use the internal 5v reference so that I wouldn't have to give up one of the 5 ADC pins for a reference voltage. The downside for the Sharps then, is that I'm not using the full range of resolution -- the Sharps output ~0-3v so I get readings of ~ 03-510 -- but that's still an order of resolution higher than an 8-bit ADC -- and no external circuitry is required. If you want more precision, you can put a 3v voltage divider across the reference pin.
I'm also using the dedicated PWM pin to control brightness of some LEDs, and the built-in pull-ups on Port B are nice for button input and the like.
One comment -- since what you are really buying is the firmware that Devantech coded into the chip (a PIC) you might want to pick up a spare or two -- I don't think Devantech is going anywhere, but in 5 years if you burn the chip, it might not be so easy to replace.
www.robot-electronics.co.uk/htm/gpio14tech.htm
Thx for your·reply. But I I still would like to know, if it is possible to program with PBasic in order to read the data sent by the GP2D12.
I have already a SRF235 connected to my BS2px and working very well. I want to use the 2 detectors together. When I have added the GPIO14, I connected the SDA-SDA, SCL-SCL between the 2. I got the +5 V from the Vdd & the Grd from the Vss both from of the BOE. The +5 V of GP2D12 is connected directly to the Vdd of the BOE, same for the Grd.The Vout to AN0 of the GPIO14.
I hope I did not make any stupid thing with these connections!!!
Do·you have any hints about the PBasic Commands?!!
Tanks again
Doc
Connections:
1 -- SDA of any I2C devices (incl. GPIO14) -> pin 0 or pin 8 of Stamp
2 -- SCL of any I2C devices (incl. GPIO14) -> pin 1 or pin 9 of Stamp
3 -- 1.8k-4.7k pull-up resistor between SDA pin and +5v (only one pullup needed on I2C bus) - standard is 4.7k; I usually use 2k for better noise immunity
4 -- 1.8k-4.7k pull-up resistor between SCL pin and +5v (only one pullup needed on I2C bus) - standard is 4.7k; I usually use 2k for better noise immunity
5 -- Sharp output pin to AN(0..4) of GPIO
6 -- +5v and gnd connections to sharp
Programming:
Use I2COUT command (see Pbasic Manual) to setup your ports, ADCs, etc. on the GPIO14. See the GPIO14 documentation for details. In this case, I'm presuming using internal +5v reference which will give you about 9bits of resolution on the 3v Sharp, right justified data. Then use I2COUT and I2CIN to get an ADC conversion:
Post Edited (Zoot) : 2/15/2007 3:26:40 PM GMT
But do not you think that a 100 nF capacitor is needed between the Vdd +5 V·supply and·Vss (Grd) of the GPIO14 or it is not essential?
Doc
A good rule of thumb for any integrated circuit is to put a decoupling capacitor (.01.uf-.1uf) between Vdd and Vss right at the chip. Depending on the chip(s) and the design it is not uncommon to also put a 10uf cap across the power rails at the chip also. It mostly depends on the current draw and purpose of the chip. For example, the GPIO14 can sink/source 25ma per pin (which is pretty beefy). If you are running a bunch of LEDs from the ouput pins you might want a 10uf cap also.
That said, I've found the GPIO14 (PIC) to be pretty insensitive to noise and voltage fluctuations on the power rails.
I am using this code:
SDA···· PIN 8················ ' SDA on PIN 8
GPIO14 CON $40············· 'GPIO14 address
cmdReg CON $00············· 'command register
ADreg CON $03·············· 'AD control register
resultReg CON $01·········· 'result register
Code VAR Word
Reset:
· I2COUT SDA, GPIO14, ADreg, [noparse][[/noparse]%11000000]
DO
·I2COUT SDA, GPIO14, cmdReg, [noparse][[/noparse]$03 + 0]
·PAUSE 10
·I2CIN SDA, GPIO14, resultReg, [noparse][[/noparse]Code.HIGHBYTE, Code.LOWBYTE]
·DEBUG 1, DEC5 Code
·LOOP
The problem is that the output result is not stable. The code generated with the debug command is not the same for the same distance, it keeps on changing without touching the detector.
Any idea please?!
Doc
On my detectors, I get a workable range of about 3-510 for various distances, with a "steady-state" change of 10-15. In other words, without even moving the detector I might see things jump around from 250-260.
Remember that to make the IR detector useful you need to:
- make sure you are reading the correct A/D pin from the GPIO14
- take same calibrating measurements with an obstacle at 10cm, 20cm, 30cm ... 70cm
- run the measurements through a linearizing formula to get cm or inches
- possibly maintain a running average and/or throw away your lowest few bits on the reading to get a "stable" reading
- I have also seen where tying unused A/D inputs on the GPIO14 to ground through a 10k resistor will help make used A/Ds a little more stable
About halfway down on this page -- http://forums.parallax.com/showthread.php?p=617740 is an Excel spreadsheet that will let you plug in actual detector readings and obtain 3 constants for a linearizing formula to convert to centimeters. The file is called gp2d12_cal.xls
For the moment, I just need to have a stable code for one fixed distance. Than I will work on calibration and linearisation with excel doc you have sent to me (Thanks a lot by the way).
well I have made few measurments, arround 200 with 10 ms interval, I got the min code 245 and the max 311 for the same distance.
The GP2D12 (+5V) pin and the GPIO14 VCC (+5V) pin both are connected to the Vdd (+5) of a BOE-USB. I am working also on the AN0.
Actualy I will recover the code in a VB6 GUI and I will fixe the calibration in there.
As·it is 10 bits data from the GPIO14, so I must have a code beween 0 - 1023. But since the GP2D12 max Vout is 3 V (2.5V) so the max code should be 614 (511), right?
But I still find it strange this 245-311 jump for a fixed position, NO?
By the way, are you using a voltage divider?
There are a number of articles that suggest putting a 33uf cap across the output pin and gnd pin of the Sharp to stabilize the output; I haven't tried that because I didn't really have the physical space to do that right at the detector.
However, for stable readings, unless you need greater precision than 1cm, I would calibrate and linearize, THEN see what kind of jumps you get.
Voltage divider -- I am not using one (I think we covered this above?) for two reasons:
- I have some analog inputs that are in the 0-5v range and some that are in the 0-3v range (Sharps).
- if you do use a voltage divider, then you sacrifice one analog pin on the GPIO14 (you need to feed the reference voltage in somewhere!)
But if you want greatest precision, and having only 4 analog inputs, all referenced to 3v, is OK, then a voltage divider for the AREF pin would be in order. Remember to write the correct mode to the A/D control register before taking readings.
Lastly, I guess in theory for 10bits of 3v readings against 5v reference you might get numbers as high as ~600, but that also presumes the detector is actually reaching a "perfect" 3v. The Sharps output a higher voltage the CLOSER you get, and if you get too close (<4cm or so) the voltage DROPS again...so there is really a very tiny sweet spot where you actually see max. voltage. Then add possible variations in the detector itself, actual resistance in the wiring to your GPIO14, etc., and y ou may not ever hit 3v exactly.
Actually I am looking for a 0.1 mm Precision, so if the voltage divider can help, I will sacrify one A/D.
But how come you managed to have only 1-3 bits changing?
Crunching some numbers, if you use a voltage divider for a 3v reference, in an ideal world you would get:
3v / 1024 steps of resolution = 2millivolt resolution
Or given the real useful range of the Sharp (10-80cm = 70cm):
70cm / 1024 = .06cm resolution -- wouldn't that be .6mm precision at best? And you might lose a little more precision after averaging out at least a bit or two? Aaargh -- I haven't had enough coffee yet this morning for math.
I will try my best to use this IR at max.
Enjoy your coffee and have a nice day/evening.
Cheers
