Reading Composite video - tips
I am thinking about building a system that reads composite video and writes it to an SD card. I have searched through the forums and cannot find anything on reading composite video and storing it. The application is to read a reasonable resolution·camera·stream such as a color lipstick camera (TV resolution - much higher than webcams).·I have found some useful information on·writing to the SD card. I am more looking for some specific informaton on using the Propeller with composite video.·I am just in the beginning stages of my investigation into how to put this together and would appreciate some pointers if anyone knows of some reference information?
Thanks in advance.
Thanks in advance.
James
Some extra memory wouldn't hurt either.
If you store 256x192 pixels @ 4 bits each (16 gray levels) that would be 24K.
The SD card is not nearly fast enough to store the image directly.
Storing color images would be alot more complicated because you need to phase lock to the color burst frequency.
Bean.
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
www.conexant.com/products/entry.jsp?id=203
Mahjongg
These chips include the 1/18" array that can be fitted in a capsule and swallowed, I don't have a price on that one yet however.
Graham
