building r/c sumo bot, need desperate help
Hi everyone, I've been searching around on the internet for a while now and seem to be just getting more confused by the minute. I have recently been informed that I need to build a sumo bot for my school's scioly team in the next month. it can be R/C, so no micro controller is needed, but i just wondered if someone could get me a push in the right direction. I read the article on how to build an r/c robot, but I am having trouble finding all the parts online, and my main worry is that the parts I buy won't be compatible together. anyways, the robot has to be able to fit in a .5 meter cube and run on 18 volts or less. can anyone give me a list of parts or something that I should start off with? Thanks so much in advance, I really appreciate it. I'm desperate here.
-James
-James
I think you should first decide what you want your BOT to do. Do you want a ready-made chassis? Have a look at the sumo-bot documentation here on Parallax's website. Theirs uses one of their microprocessors, but it is a sumo-bot and you may be able to get some ideas from it. It does use two servos.
Edit: how would i get the servos to continuously rotate?
several of the surplus parts sites should have what you want and the hobby shop should have radio control.
- Stephen
Continuous rotation servos are modified standard servos. You can do it yourself (there are instructions on the web) or buy them already modified. Basically, the position feedback mechanism in the servo is disabled and the pulse width specifies the speed and direction of the rotation rather than the absolute position.
- Stephen
