BS1-USB newbie question
eddie69
I am new to this whole stamping experience, so please excuse my ignorance. I am trying to get a PIR sensor Module (Parallax # 555-28027)·to interact·with a BS1USB card using Visual Basic 2005. I have read some other posts in which they referenced VB net, but have not find to much help there either.
Basically, I want to be able to manage an VB application depending on the input state change of the PIR sensor. More like a security system in which the VB application will do something like making a sound or send an email if the PIR sensor changes state.
I am not sure if this could be done just with these materials, or I might have to adquire something else. So far I only have a BS1USB and PIR sensor.
I have the PIR sensor wired to BS1 using Vdd to provide power and Vss to provide ground. The Out from the PIR sensor comes in to the BS1 pin 0.
I have not been·able to verify the simplest functionality, a least to see it I could monitor any input state changes using Basic Stamp Editor in Debug.
Any help or direction will be really appreciated,
Respectfully,
Eddie
Respectfully,
Eddie
- Stephen
This will help you http://www.parallax.com/dl/docs/cols/nv/vol7/col/NV131.pdf
Bean.
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
Once again, thanks for the kind responses.
Dou you recommend another USB module better suit for this kind of job?
What is the main difference between bs1 and bs2 programming?
What will be needed to get an on/off command across USB to an application?
Once again thanks for your time,
Eddie
