RS232-connections To a pc
nomad
RE: RS232-connections To a pc
hi folks,
i am interesting to build a rs232-connection from a propeller-chip to
a linux laptop and visiversa.
first question (hardware):
is the circuit description found under SerialtoPropeller.pdf
the only one????
or its possible to build the hardware with a
"MAX 3222 CPN - IC" (DIL 18)
(vcc: 3...5.5Volt, and 4 x condensators at 0.1uF)
have you any suggestions and layouts for me???
second question(software):
on the "simple_Serial-spin"
part.............
·code:··
· if lookdown(rxPin : 0..31)··························· ' qualify rx pin
··· sin := rxPin
··· inverted := (baud < 0)····························· ' set inverted flag
··· .....·············································· ' calculate serial bit time
· if lookdown(txPin : 0..31)
··· sout := txPin
its possible insteed of if lookdown(rxPin : 0..31) or
to do that (that only pseudoCode)
p8·· == rxPin········
sin· := rxPin
p9·· == txPin
sout := txPin
third question:
···· serial.start(0, 1, -9600)
is this statement correct for
·· baud··· : 9600
·· Databits: 8····
·· Paritaet: none
·· stopBits: 1
thanks for all answers
as attachments:
simple_Serial-spin
greetings
nomad
hi folks,
the only one????
part.............
·code:··
··· sin := rxPin
··· sout := txPin
sin· := rxPin
p9·· == txPin
sout := txPin
third question:
·· baud··· : 9600
·· Databits: 8····
·· Paritaet: none
·· stopBits: 1
as attachments:
simple_Serial-spin
greetings
nomad
thanks for your answer.
but i am living in switzerland and have no connection to this company.
greetings
nomad
I have built a serial to propeller circuit using an ST232 - ST microelectronics version of the MAX232 - a 3v capable version.I made a quick schematic for you (attached)·- hope it helps.
I have also included the PDF of the suitable 232 driver Vcc range from 3v to 5.5v - so its suitable for the 3.3v supply ... and a pdf of a 24lc256 DIP package with a VCC range from 2.5v to 5.5v -·again suitable for 3.3v operation.
Might also be worth while reading the following thread ...
http://forums.parallax.com/showthread.php?p=626362
Have now named the transistor Q1 correctly in my sample ! - also added some app nortes...Rgds,Quattro
Post Edited (QuattroRS4) : 2/13/2007 3:58:18 PM GMT
first excuse, i have read first your PM, and don't found the attachments.
now its all ok.
thank you for your help.
regards
nomad
Rgds,
Quattro
I wasn't sure either so the example I gave can be used to program AND communicate ...
After the device is programmed a simple 3 wire cable can be used for communication i.e. rx,tx,gnd if someone so wished. This gives the option to use it for both - I also attached a link in an earlier post where by I ran serial tx from prop to hyperterminal without any 232 support i.c - just a 4.7K resistor ... not really ideal but works as a test .
here I posted:
Quattro Post Edited (QuattroRS4) : 2/13/2007 8:58:02 PM GMT
I'm new at this so sorry if this question is kind of dumb, but is there a schematic anywhere that shows this simple communication circuit? I have a MAX3232 and a few 0.1uF capacitors but the circuit i was viewing also required a transistor or two and was once again aimed towards programming. I am attempting to communicate with a MaxStream RF modem through serial and I'm still trying to figure out how to do so.
Anyway, thanks in advance.
woh......
thanks for all answers...
excuse my unclear question.
i want only communicate with the linux laptop via rs232,
NOT programming.
and thanks for the reference to the MAX232
first i buy the stuff and then build and test the whole stuff.
and then i make a call to the forums.
and excuse my bad english.
thanks to all people
regards
nomad
now i have look on your Nomad_Sample.PDF
thanks for the layout.
first i have a) PropellerChicp-DemoBoard
·············· b) PropStickUSB
the rs232-communications should be running on both devices
=> DemoBoard only for testing the stuff
=> production on PropStickUSB my project a QuadraPod Spider
few questions:
first: with the PropStickUSB (32210propstickusbv1.1.pdf)
the pins 28-31 are used:
·· - 28/29 -> eeprom
·· - 30/31 -> usb-connections
so, can i use another pins for the added rs232 connection??
perhaps pin 0 pin 1 ?
attachment: 32210propstickusbv1.1.pdf
greetings
nomad
You sure can use the same theory as the example shown to use other pins for serial coms. If you see the Quote I included from a different post whereby I ran a test for serial coms without a 232 driver. You can do the same but I recommend that you use the driver.
Quattro[noparse][[/noparse]code]CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
OBJ
ExtSerial : "FullDuplexSerial"
Pub Test1
extserial.start(1, 0, 2, 9600) ' rxpin,txpin,mode,Baud - depends on your set up
repeat 5 ' repeat 5 times
·extserial.str(string("Hello World"))
will send 'Hello World'
'extserial.start(1, 0, 2, 9600) ' rxpin,txpin,mode,Baud -adjust to suit your needs
Post Edited (QuattroRS4) : 2/14/2007 1:47:04 PM GMT
i have a look to my distributor:
- no ST232 available but
the MAX2322· as attachment: the datasheet
i think that is basically the same stuff???
so, after study your nomad_sample.pdf
(yeah a pdf with my name ;-))
i think i must build only the rs232-circuit(leftUp)
and change the pins.
greetings
nomad
The version you have shown here··is the same and is a 3v to 5.5v version so it will be fine..
QuattroRS4
Post Edited (QuattroRS4) : 2/14/2007 1:51:05 PM GMT
thanks for your help.
first:
i am verry careful.
now i buy the MAX 3222 AND the MAX 3232·
for all possiblities
second:
i have read your answer.
you write:
<<I ran a trial just now for you
- using a demo board -
to a laptop which has a third party
usb to serial device as its serial port>>.
my answer: yes i have this devise on german: usb to rs232-Adapter.
no proplem with the linux laptop
your write:
<< connections as follows
- Vss on demoboard to pin5 (gnd) on p.c serial port
P0 on demoboard through a 4.7K resistor to pin 2 on P.C serial port>>
it this right
demoboard VSS (gnd)· to ->·· serialPortLaptop Pin5 (gnd)
demoboard P0 -> 4.7K to ->·· serialPortLaptop Pin2
its correct??
if yes, woh..
on linuxLaptop i can running without problems the linuxHyperterminal or
my own serialProgram (lowLevel)
<< On the pc start up hyperterminal - 9600,N,8,1 and flow control 'None' >>
thanks verry much
greetings
nomad
Yip - I tried it out for another member and it worked fine - You may have to adjust your mode though - my test worked on both modes 2 & 3 . I wouldn't use this method as a 'finished article' - due to variances in different serial ports - i.e usb to serial adapters v real com port etc - but its fine for a trial - try it out and let me know how you get on - my example using just a resistor was purely a test - I just did a transmit from Propeller to terminal - I would strongly suggest that you use a 232 driver as discussed previously to avoid any difficulty later on ..
the electronic-stuff is here, fine.
excuse my new question:
before i soldering my RS232-circuits.
please have a look on my layout.
for me is important, that i understood the
layout for further work.
it's an adaption of your Nomad_Sample.pdf
with ST3232, the datasheet from Maxim and my ideas.
if are faults in my layout, please correct
the fault (its drawing with MS-paint)
in the next days i make the circuits and
other related work.
thank you for your trouble.
regards
nomad
········ You seem to have deviated a bit from the example - the MAX3232 has the same pinout as the ST232CN so if you follow the 'nomad_sample.pdf' (where the pin no.'s are marked) then it should be fine. Also I noticed the inclusion of the transistor and associated resistors and capacitor C5 in your drawing· - if you just want to use other pins for serial communication but NOT for programming as you have stated then these are not required and therefore neither is the connection to PIN4 on the DB9 connector (or a connection to RSTn of the propeller for that matter). So I suggest you follow nomad_sample.pdf (pin for pin - and choose the rx/tx pins on the prop to suit yourself - omitting the reset circuit if you do not want to program the Propeller through this connection·) you can also verify that here -·http://www.parallax.com/dl/docs/prod/prop/PropStick-v1.2.pdf
If you follow the same pinouts then it will be easier to debug or move on to the next step (actually using the connection) so we all know your exact configuration .
Let me know how you get on.
Quattro
thanks,
see you later
regards
nomad
i send you 2 drawings with my layout-circuits.
1 - rs232_withMAX3232_2.jpg ( changed as per your last attachement)
2 - final_RS232_Interface_withMAX3232.jpg (its for soldering purposes)
i hope the two drawing are correct.
in the afternoon and after lunch, i make the work.
regards
nomad
For a 'simple' serial connection (rx,tx & gnd) you do not require a DTR connection (pin4 on DB9)..
Quattro
hi quattro and everbody,
on saterday i am finshed the soldering of my
rs232-adapter-circuit.
(look at my final_RS232_interface_MAX3232.jpg)
and on saterday morning·i·testing the stuff
with serialTestQuadro.spin = it's your program with some testing-results:
first: tanks for the hint:
you wrote:
<For a 'simple' serial connection (rx,tx & gnd) you do not require a DTR· connection (pin4 on DB9)..>
it's fault when i have connected this 2 pins?
because i have some troubles.......
- config hyperterminal: com1, 9600,N,8,1
-·Demoboard with pin0 & pin1
- Modes on Spin: (1,2,3) all testing
Result: nothing happend.
then the same procedure with linuxBox
and my serial-C-program: nothing.
but: with a led o the rs232-connector
···· pin5 (gnd) and pin2 (+)
···· on the transmission the led blinking.
so i thing the circuit is ok.
i must say, that i have NO experience
with the windowXP (specialize hyperterm).
i am penguin-man.
so its possible that i make a fault???·
But i dont know nothing,whats the matter.
is this a hardwar- or a software- fault, or misconfiguration of
my hyperterm or my own stupidity ;.-o
attachment:serialTestQuadro.spin
for some help and advice, i am verry grateful
regards
nomad·
This is the easiest sample I can think of to debug the circuit - no 232 driver
pin5 of DB9 (GND)·
> VSS demo Board (GND)
P0 of demo Board through a 4.7K resistor to Pin2 DB9
·***** on other models of USB to serial adapters the resistor value may have to be lower - i.e 2.2K
·And run the sample program you attached in the last post -
·I ran the test on my Lap top and it was fine - So I changed the USB to serial adapter to another type and it would not work with a 4.7K resistor but did work when I used a 2.2K resistor (try put 2x 4.7K resistors in parallel)... I have included low res images of the circuit, cable (notice only 2 wire as this is a transmit only sample tx & Gnd) and the hyperterminal window - the sample spin prog·is fine ..... Hyperterminal setup is as follows -·Bits per sec: 9600 ,Data Bits: 8 ,Parity: None, Stop Bits: 1, Flow Control: None· ....·let me know
Post Edited (QuattroRS4) : 2/17/2007 7:43:14 PM GMT
thanks for your prompt answer.
now on sunday-morning,
i am testing the stuff.
see you later
regards
nomad
i am verry frustred and not amusing after 4 hours of testing
first: testing
1 testing hyperterminal
1-new connection -> new name: propeller3
comport: COM1 -> ok
property of com1:
- baud:······· 9600
- databit:···· 8
- paritaet:··· NONE
- stoppbits:·· 1
- flowcontrol: NONE
button -> take over (the right button)
button -> ok
run with serialTestQuadro.spin nothing
but led transmit = ok
some times later nothing goes.
no transmission no led
on MAX3232 PIN 7 -> -5.52VOLT
with a new chip the same stuff.
Second:
then a testing the serial communications with 2 linux-boxes.
Send and Receive Data ok.
Third:
testing
demoboard with this program and the linuxBox:
a) only the simple way: rs232-adapter pin5 -> gnd·· on demoboard
····································· pin2 -> pin0· on demoboard
b) with the adapter
CON
OBJ
Pub Test1
extserial.start(-1, 0, 2, 9600) ' (transmit only)- rxpin,txpin,mode,Baud
······························· '· - depends on your set up
repeat 100 ' repeat 5 times
· extserial.str(string("Hello World\r"))········ ' the \r is the carrige return for unixes
· waitcnt(100_000_000 + cnt)···················· ' end of 1 read
result: not running and linux was not amused -> restart
so in the moment i find no solutations for this problem.
is the a hardware or a software-problem (look at my latest posting)
i not understand why on the propellerChips are no existing simple debug-method.
look at basic stamps one "debug-statements: a rs232-line to a linux box and
all running.
and hyperterminal is typical software from microsoft.................
in the last year i have build 3-wheel-robot of the 10kg - class:
- 3 microcontrollers, 9 sensors, gps, networkCameralook as masterController
a 64-bit linuxLaptop with a artifical network for the avoidance and a second
for picture-recognize.
in the moment i think i must take· other microcontroller for the communications
· propeller-chip· <-> mc <-> (serialLine) LinuxBox
· the better way was:
· propeller-chip (one coq- for communications) <-> linuxbox
what you think about of my problems
thanks
regards
nomad
