stepping a stepper
I need to drive a stepper motor for a predetermined number of steps.· The driver is no problem, but I am looking for a way to generate the step pulses.· The pulses must ramp up to about 5,000 Hz to allow the stepper to speed up from zero to full speed.· I am thinking the Pulseout command is the one for the job, in some kind of a timing loop.· But changing the frequency without jitter sounds tricky.· Am I on the right track?
The "little step u" driver module has programmable ramp-up and ramp-down rates.
http://www.parallax.com/detail.asp?product_id=27938
Or the SX (not BS2SX) could do it easily.
http://www.parallax.com/detail.asp?product_id=45181
If you happen to have the professional development board, all you need is the SX-Key or SX-Blitz to program the SX chips.
Bean.
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
