Need help with my 8 bit LCD code
Capt. Quirk
I have been working for months now on trying to develop my own 8 bit LCD SX/B code. I have a few converted BS2 programs that will display a message, but I need to display real time data and Bean's last contribution will fix that (thanks Bean).
Also thanks to·Jonny Mac, the Debuging info has been helpful, but I am still working on·intergrating assm examples into sx/b.
The code I am posting, I was trying to make use of the latest SX/B 1.5 changes and kinda used the BS2PE commands as a guideline to what can be done with SX/B. I been trying to do it this way in order to better learn the SX-Key and SX-Sim debugging tools, but watching data flow and execution timmings for this hitachi parallel clone has lead me to whits end.
So far this code seems to flow right, but I think I am still·have some timming issues. The best I have gotten so far was, a underline cursor, but it didn't blink like it should have.
'·· File...... myOwnLcdCode_test.sxb
'·· Purpose... SX/B LCD Initialization routine
'·· Author.... Bill Mazzacane
'·· E-mail....
'·· Started...12/02/07
'·· Updated...
' Program Description
' Device Settings
· DEVICE········· SX28, OSCHS2, TURBO, STACKX, OPTIONX
· FREQ··········· 4_000_000
· ID············· "SXB 1.50"
'· IO Pins
· ctrlBus·············· ·VAR···· RA······················ ' Enable pin
· lcdBus················ VAR··RB
'· RA.1 = E
'· RA.2 = RW
'· RA.3 = RS
'· 8 Bit data = RB.0 thru RB.7
' Constants
' None
' Variables
· char··········· VAR···· Byte··················· 'character sent to LCD
· idx············· VAR···· Byte··················· 'loop counter
· temp1········· VAR···· Byte ·················· 'Byte variable passed to subroutine
· PROGRAM Start
Msg:·····
········· DATA· "The SX RULES!", 0·· ···' store message
' Subroutine Declarations
LCD_CMD····SUB, 1·······'Main contol subroutine
' Program Code
Start:
··PAUSE 100··································· ' let the LCD settle
·TRIS_A = %0000······························ 'Set RA to outputs
·TRIS_B = %00000000
Lcd_Setup:
· LCD_CMD %00110000 ···················· '8-bit mode, lcdBus remains at steady state·······
··· ················································ 'until changed
· LCD_CMD %00001110·······················'on, crsr, blink, **** For Debug only ****
· LCD_CMD %00000110 ···················· 'inc crsr, no disp shift·························
Main:
· DO
··· READ Msg + idx, char······················'get character from EE
· IF char = 0 THEN EXIT······················ 'if 0, message is complete
·· ·LCD_CMD char·······························'write the character
··· idx = idx + 1································· 'point to next character
· LOOP
END····································
' Subroutine Code
LCD_CMD:································ 'Main contol subroutine
·· ctrlBus = %0000 ···················· 'Set lcd for input
·· temp1 = __param1·················· 'Pass byte variable
·· IF temp1 = %00110000 THEN··'Instruction for 8 bit interface, No busy flsg is required
·· lcdBus = temp1······················· 'Pass byte variable to lcd
·· PULSOUT RA.1, 0····················· 'Strobe enable
·· PAUSE 5································ 'pause 5 m/s
·· PAUSEUS 100·························· 'Pause 100 u/s
·· PULSOUT RA.1, 0······················ 'Strobe enable
·· ctrlBus = %0011······················ 'Reset SX to recieve data from lcd
ELSE··························· ·' All other instructions use the busy flag
·· ctrlBus = %0100······················· 'set E high before variable is sent
·· lcdBus = temp1························ 'Pass byte variable to lcd
·· ctrlBus = %0000························ 'set E low to allow variable to send
·· PAUSEUS 200······························ 'Pause 200 u/s
·· ctrlBus = %0010······················· 'set RW high before checking busy flag
·· TRIS_B = %11111111················ 'set RB for input
DO UNTIL RB.7 = 0···················· 'wait for busy flag to clear
··· PULSOUT RA.1, 0···················· 'Strobe enable before checking busy flag again
LOOP
· TRIS_B = %00000000··············· 'Reset RB for output
·ENDIF
RETURN
' User Data
'tried using the busy flag with the SX since the timming is so much faster than the BS2.
'LCD clock @ 2Mhz
Pgm_ID:
· DATA· "SX/B 1.50 Template", 0
Post Edited (Capt. Quirk) : 2/13/2007 1:19:36 AM GMT
'·· E-mail....
'·· Updated...
' Device Settings
'· IO Pins
'· RA.1 = E
'· RA.2 = RW
'· RA.3 = RS
' Constants
' None
' Variables
· PROGRAM Start
Msg:·····
' Program Code
Start:
·TRIS_B = %00000000
Lcd_Setup:
Main:
· DO
· LOOP
' Subroutine Code
LOOP
·ENDIF
RETURN
' User Data
'LCD clock @ 2Mhz
Pgm_ID:
Are you using a 4MHz resonator ? OSCHS2 is good for 4MHz. Try OSCXT1.
If you want to use the internal 4MHz, then use OSC4MHZ on the device line.
Bean.
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
I know the set-up works. It's on a profesional development board and when I switch the wires over to the BS2, I get a full display in 8 or 4 bit mode and the 4 bit SX assm code works great too.
Yesterday I used the SX-Sim for the first time and figured out the time involved for each line of code and using the hitachi timming diagrams and I thought I would finally get it to work. but nogo. This code is based off that previous days work, but I tried to keep it a bit more simple. I thought by using a "control bus", I could more accurately control functions like "pulsout" and control the times with "pause" & "pauseus"·. much of the code exucuted in .02 - .05 u/s.
I did make one change since the post, but I don't think it helped (idx = 0).
Post Edited (Capt. Quirk) : 2/13/2007 12:05:14 AM GMT
I really think it's funny that the night before I receive my new serial LCD, I figured it out. LMAO !!
It's defiantly not a bad thing, I have been wanting to use the "Example Code" to to serial in my ADC info and interface the LCD to a few buttons or a·4 x 4 keyboard. (no reason to carry around a lap top, huh).
Thanks Bean & Jonny Mac for the help.
Bill
