GPS Module
Hi i find it hard to work with the GPS module indoors. This is because it is hard to find and keep a signal from a satellite. So i was wondering if it would be possible to create some kind of antenna to attatch it it. I would need to be able to do this without any type of modifications to the actually component itself. Any information would help because i am not exactly even sure what part of the module picks up the signal. Thanks in advance for your help.
Post Edited (mgoehle) : 2/12/2007 2:18:38 AM GMT
On a second note, getting the plus or minus 'foot' accuracy needed for indoors, isn't even available outdoors. It at best would tell you what room you were in. Sorry but the GPS units need to be outdoors.
HTH, Chris
