RCTime question — Parallax Forums
RCTime question
Capt. QuirkCapt. Quirk Posts: 872
edited 2007-02-12 15:58 in General Discussion
Rctime returns·an 8 bit value·and uses multipliers expand it's capabilities (I think) , But when my servo control program went to "zero" (bad code). RCTime would quickly return a value of 65,000 + as if was really a 16 bit variable?
Why does it do that?.
  • JonnyMacJonnyMac Posts: 9,826
    RCTIME can return a word; the multiplier parameter affects the units of [noparse][[/noparse]internal] timing. By default, it's 2 microseconds (like the BS2), but you may want a longer timer if you're using a big RC circuit (e.g., photcell that has huge off resistance).
