is it possible to change SX/B 8 bit Commands into 16 bit?
Capt. Quirk
I was trying to use Ken Gracy's .bs2 mill example into SX/B code and ran into a problem with "LOOKDOWN" requiring only 8 bit variables and so I was thinking maybe by combining RB & RC ports to "RBC".
Would that allow 16 bit variables then? and would that work across the board for other commands that require a 0 - 255, 8 bit variable.
If you declared the variable
wordvariable WORD
and then did this
RB = word_LSB
this would output the LOWER BYTE of the word to the port RB
and
RC = word_MSB
this would output the UPPER BYTE of the word to the port RC
this feature is not documented well in the help sections.
Meh. Nothing here, move along.
"Lookdown" requires a Byte variable·or a number value between 0 - 255 and so do a lot of other commands like RCTIME, PULSOUT, etc. If you need a variable like 10,000 and declare it as a word, SX/B returns an error declaring a "expected Byte varible".
With some of the Commands you can use multipliers to prevent this, but others you can't. Thats why I thought RBC may fix that.
Post Edited (Capt. Quirk) : 2/11/2007 1:47:14 AM GMT
Got a link to your code?
' Write right-justified value at cursor position
' -- move cursor to left-most position of field
' -- put field width if 'width' (1 to 5)
' -- put value in 'value'
'EXAMPLE FROM HELP SECTION
' idx = 3
'LOOKUP idx, $00, $01, $02, $04, $08, $10, $20, $40, $80, LEDs
LCD_Put_RJ_Value:
· LOOKDOWN value, >=[noparse][[/noparse]10000, 1000, 100, 10, 0], pad ········ 'Gives error #11 "Byte Variable Expected"
· pad = pad - (5 - width)················································ 'All 7 errors are within this routine
· IF (pad > 0) THEN······················································· 'I was planing on checking this version with
··· char = " "····························································'SX-Key Debug and compare results with the actual
··· FOR idx = 1 TO pad·················································· 'BS2 program
····· GOSUB LCD_Write
··· NEXT
· ENDIF
· FOR idx = (width - pad - 1) TO 0
··· char = value DIG idx + "0"
··· GOSUB LCD_Write
· NEXT
· RETURN
·The actual program
'·· File...... Mill_Speedo.SX/B
'·· Purpose... Wabeco CC-1210 Milling RPM Measurement
'·· Author.... K. Gracy?
'·· E-mail....
'·· Started...04 JUN 2004
'·· Modified by..Bill Mazzacane
'·Updated... 10 FEB 2007
' Program Description
'In the process of changing it over to SX/B
' Device Settings
DEVICE········· SX28, OSCHS2, TURBO, STACKX, OPTIONX
FREQ··········· 20_000_000
ID············· "SXB 1.50"
' IO Pins
E·············· PIN···· RB.1························ ' LCD Enable
RW············· PIN···· RB.2······················ ' Read/Write\
RS············· PIN···· RB.3······················· ' Reg Select (1 = char)
LcdDirs········ VAR···· RB···'DIRB···············' dirs for I/O redirection
LcdBus········· VAR···· RB···'OUTB
SpeedIn········ PIN···· RC.0····················· ' Melexis 90217 output
' Constants
'#DEFINE Lcd = 1·································· ' set to 0 for VFD
'#DEFINE BarGraph = 1··························· ' set to 0 for no graph
LcdCls········· CON···· $01······················ ' clear the LCD
LcdHome········ CON···· $02···················· ' move cursor home
LcdCrsrL······· CON···· $10······················ ' move cursor left
LcdCrsrR······· CON···· $14······················ ' move cursor right
LcdDispL······· CON···· $18······················ ' shift chars left
LcdDispR······· CON···· $1C······················ ' shift chars right
LcdDDRam······· CON···· $80···················· ' Display Data RAM control
LcdCGRam······· CON···· $40···················· ' Character Generator RAM
LcdLine1······· CON···· $80······················ ' DDRAM address of line 1
LcdLine2······· CON···· $C0······················ ' DDRAM address of line 2
A····CON··10_000
B····CON··1_000
D····CON··100
R····CON··10
F····CON··0
' Variables
char··········· VAR···· Byte···················· ' for LCD
addr··········· VAR···· Word··················· ' ee pointer (for DATA)
pulses········· VAR···· Word··················· ' input pulses from motor
rpm············ VAR···· Word··················· ' motor RPM ###### Needs to be a byte ############
percent········ VAR···· Byte··················· ' % of max speed (7500)
fldPos········· VAR···· Byte····················· ' field position
value·········· VAR···· WORD··················· ' value to print #########Needs to be a byte #######
width·········· VAR···· Byte····················· ' width of print field
pad············ VAR···· Byte······················' spaces for rj printing
idx············ VAR···· Byte······················ ' loop counter
cols··········· VAR···· Byte······················ ' total graph colums
blox··········· VAR···· Byte····················· ' whole blocks for graph
· INTERRUPT
ISR_Start:
· ' ISR code here
ISR_Exit:
· RETURNINT ' {cycles}································
· PROGRAM Start
[noparse][[/noparse] EEPROM Data ]
Banner1:········
·DATA·· "·· KEN GRACEY·· ", 0
Banner2:········
·DATA··· "MILL SPEEDOMETER", 0
DefaultL1:······
·DATA·· "·· 0 RPM···· 0 %", 0
'#IF Lcd #THEN
· 'CC0·········· DATA·· $10, $10, $10, $10, $10, $10, $10, $00
· 'CC1·········· DATA·· $18, $18, $18, $18, $18, $18, $18, $00
· 'CC2·········· DATA·· $1C, $1C, $1C, $1C, $1C, $1C, $1C, $00
· 'CC3·········· DATA·· $1E, $1E, $1E, $1E, $1E, $1E, $1E, $00
· 'CC4·········· DATA·· $1F, $1F, $1F, $1F, $1F, $1F, $1F, $00
'#ENDIF
' Subroutine Declarations
Show_RPM····SUB
Show_Percent···SUB
LCD_Put_String···SUB
LCD_Put_RJ_Value··SUB
LCD_Command····SUB
LCD_Write····SUB
' Program Code
Start:
· TRIS_B = %11111101····························· ' setup pins for LCD
· LOW RW
LCD_Init:
· ·PAUSE 500·········································· ' let the LCD settle
· ·LcdBus = %0011··································· ' 8-bit mode
· ·PULSOUT E, 1·
·PAUSE 5
· ·PULSOUT E, 1
·PAUSE 0
· ·PULSOUT E, 1
·PAUSE 0
· ·LcdBus = %0010································ ·' 4-bit mode
··PULSOUT E, 1
· ·char = %00101000······························ ' multi-line mode
· ·GOSUB LCD_Command
· ·char = %00001100······························ ' disp on, no crsr, no blink
· ·char = %00000110······························ ' inc crsr, no disp shift
'NOT REQUIRED
'DL_Characters:
'#IF Lcd #THEN
'char = LcdCGRam································· ' point to CG RAM
'GOSUB LCD_Command··························· ' prepare to write CG data
' FOR idx = CC0 TO (CC4 + 7)·················· ' build 5 custom chars
' READ idx, char···································· ' get byte from EEPROM
' GOSUB LCD_Write································ ' put into LCD CG RAM
'NEXT
'#ENDIF
Banner:
· char = LcdCls
· GOSUB LCD_Command
·· DO
··· READ Banner1 + addr, char
··· addr = addr + 1
··· IF char = 0 THEN EXIT
··· GOSUB LCD_Write
· LOOP
· GOSUB LCD_Put_String
· char = LcdLine2
· GOSUB LCD_Command
·· DO
··· READ Banner2 + addr, char
··· addr = addr + 1
··· GOSUB LCD_Write
· LOOP
· PAUSE 3000
· char = LcdCls
· GOSUB LCD_Command
Main:
· addr = DefaultL1
· COUNT SpeedIn, 1000, Pulses
· RPM = Pulses * 60
· GOSUB Show_RPM
· 'percent = rpm / 75
· GOSUB Show_Percent
· GOTO Main
' Subroutine Code
Show_RPM:
· char = LcdLine1
· GOSUB LCD_Command
· width = 4
· value = rpm
· GOSUB LCD_Put_RJ_Value
· RETURN
Show_Percent:
· char = LcdLine1 + 11
· GOSUB LCD_Command
· width = 3
· value = percent
' NOT REQUIRED
'#IF BarGraph #THEN
'char = LcdLine2······························· ' position cursor
'GOSUB LCD_Command
'cols = percent */ 205······················· ' x 0.8 (100% = 80 pixels)
'blox = cols / 5································ ·' calculate whole blocks
'IF (blox > 0) THEN
'char = 4
'FOR idx = 1 TO blox.
' GOSUB LCD_Write
' NEXT
'ENDIF
' LOOKUP (cols // 5), [noparse][[/noparse]" ", 0, 1, 2, 3], char····· ' partial block
'GOSUB LCD_Write
'char = " "
' FOR idx = 0 TO (16 - blox)························· ' clear end of graph display
' GOSUB LCD_Write
' NEXT
' #ENDIF
'RETURN
' Writes stored (in DATA statement) zero-terminated string to LCD
' -- position LCD cursor
' -- point to 0-terminated string (first location in 'addr')
LCD_Put_String:
· DO
··· READ addr, char
··· addr = addr + 1
··· GOSUB LCD_Write
· LOOP
· RETURN
' idx = 3
LCD_Put_RJ_Value:
· LOOKDOWN value, >=[noparse][[/noparse]10000, 1000, 100, 10, 0], pad ···· 'Gives error #11 "Byte Variable Expected"
· pad = pad - (5 - width)············································ 'All 7 errors are within this routine
· IF (pad > 0) THEN··················································· 'I was planing on checking this version with
··· char = " "·················································· 'SX-Key Debug and compare results with the actual
··· FOR idx = 1 TO pad··············································· 'BS2 program
··· NEXT
· ENDIF
··· GOSUB LCD_Write
· NEXT
· RETURN
' Send command to LCD
' -- put command byte in 'char'
LCD_Command:·············································· ·' write command to LCD
· LOW RS
' Write character to current cursor position
' -- but byte to write in 'char'
LCD_Write:
· LcdBus = char················································· ' output high nibble
· PULSOUT E, 3
· SWAP char······················································' strobe the Enable line
· LcdBus = char················································· ' output low nibble
· PULSOUT E, 3
· HIGH RS························································· ' return to character mode
· RETURN
' User Data
Pgm_ID:
· DATA· "SX/B 1.50 Template", 0
Bill
Post Edited (Capt. Quirk) : 2/11/2007 6:50:20 AM GMT
· The way I did this for my HC4LED displays was to put the digits in an array. Then at the end figure out how many leading digits to blank.
· If you don't need to blank leading digits, then you can just output them.
DisplayValue: IF __PARAMCNT = 1 THEN tempWord = __PARAM1 ELSE tempWord = __WPARAM12 ENDIF isNegative = tempWord.15 IF isNegative = 1 THEN tempWord = -tempWord ENDIF PUT segments, BLANK, BLANK, BLANK, BLANK DO WHILE tempWord >= 1000 INC segments(3) tempWord = tempWord - 1000 LOOP DO WHILE tempWord >= 100 INC segments(2) tempWord = tempWord - 100 LOOP DO WHILE tempWord >= 10 INC segments(1) tempWord = tempWord - 10 LOOP segments(0) = tempWord_LSB FOR cnt = 0 TO 3 READ DigitSegs + segments(cnt), segments(cnt) NEXT IF isNegative = 1 THEN segments(3) = MINUS cnt = 2 ELSE cnt = 3 ENDIF BlankZeros: IF segments(cnt) = 126 THEN ' IF digit is Zero... IF isNegative = 1 THEN PUT segments(cnt), MINUS, BLANK ELSE segments(cnt) = BLANK ' make it Blank ENDIF ELSE cnt = 1 ' Set counter to done value ENDIF DJNZ cnt,BlankZeros GOTO DisplayArrayBean.
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
Post Edited (Bean (Hitt Consulting)) : 2/11/2007 12:59:54 PM GMT
Me and array's don't get along, Would you mind going one step further and show me how you would declare that code
' ------------------------------------------------------------------------- ' Variables ' ------------------------------------------------------------------------- digits VAR Byte (5) ' holds digits for display '--------------------------------------------------------------------------------- LCD_Put_RJ_Value: ' Init digits to all zeros PUT digits, "00000" ' Convert value to ascii digits DO WHILE value >= 10000 INC digits(0) value = value - 10000 LOOP DO WHILE value >= 1000 INC digits(1) value = value - 1000 LOOP DO WHILE value >= 100 INC digits(2) value = value - 100 LOOP DO WHILE value >= 10 INC digits(3) value = value - 10 LOOP digits(4) = digits(4) + value_LSB ' Blank leading zeros idx = 0 DO WHILE idx < 4 IF digits(idx) = "0" THEN ' IF digit is Zero... digits(idx) = " " ' make it Blank ELSE idx = 4 ' Set counter to done value ENDIF INC idx LOOP ' Send digits to LCD FOR idx = 0 TO 4 char = digits(idx) GOSUB LCD_Write NEXT RETURNBean
