PID Objects and Performance
Greetings all;
I am interested in using a Propeller to run a PID feedback loop on one Cog. Does anyone have any experience with the frequency response that would be available using Spin or Assembler in a PID application? I would be needing 10kHz-20kHz capability.
Cheers!
Paul Rowntree
Cheers!
Paul Rowntree
www.mikronauts.com - a new blog about microcontrollers
Yes, speed is important, but 10kHz would be a more typical response time. We work with scanning tunneling microscopes, and the PID is used to track the motion of a sharp tip above a surface with atomic resolution. The PID keeps the tip at a constant height above each atom of the surface; if the PID is too slow, the tip hits the surface and usually damages the tip and or the surface.
We have used analog control loops and DSP based systems; I was wondering if a Cog/Propeller system could do it as well. For the cost of a chip, it would be an easy experiment to try.
Cheers!
Paul Rowntree
Very cool appilcation; wish I had your toys!
Check out http://www.motionsystemdesign.com/Issue/Article/17779/Moving_with_modified_PID_loops.aspx you might find it useful.
A fixed point PID should run more than fast enough in a cog.
