write instructions
I've finally found the time to start playing with this chip and I'm really excited about it. After reviewing the assembler instructions I keep confusing myself with the write instructions. They seem backward compared to all the other instructions. Everything else appears to be 'normal' for me as (instruction-destination,source) but the writes are writing the destination to the source?
The other thing is that, if the Hub address is in the source field, you can use the immediate operand mode to access the first 512 bytes of Hub memory more easily for both reading and writing.
