RFID readers
I have recently entered a competetion where the goal is to build a electronic device, and the one that came to mind was a RFID operated lock since they have them all over the school i go to and should be fairly simple to build.
But since im on a tight budget i figured·i should look for something other then the parallax design, i came across a "ID12 RFID Reader Module" at http://www.rfidshop.com/index.asp?function=DISPLAYCAT&catid=240, and i figured that it should fit my needs just fine.
But since im failry new to electronics i was wondering if it was possible to hook it up, i figure it should be since it needs 5V regulated which the board already does, and it needs 200mA which is also the same, so as long as i hook it up right it will work for an RFID reader right?
It reads at 125khz which the parallax cards work, so as far as i can tell it is the perfect thing for a door lock.
When you see the pretty smoke come from a component. It is time to go shopping again.
That said, I looked at the on-line documentation and it ought to work as you (and the documentation) describe. It needs 5V at a current that the Stamp development boards with a regulator can supply (like the Super Carrier or BOE). It seems to talk logic level serial I/O which the Stamps know how to do. Good luck!
From the little bit i read about the parallax reader it uses the 12-byte ASCII structure, but what does this mean?
Post Edited (Monkey4sale) : 2/9/2007 6:51:45 PM GMT
- Stephen
The RFID Reader you mentioned does operate @ 125 KHz, but frequency isn’t everything…There is a unique protocol to the tags/reader and yours specifies EM4001, whereas ours specifies EM4100. Another different is yours refers to 64-bit ID whereas ours is 40-bit I believe. These are all things to take into consideration when choosing Cards/Readers that match up. I hope this helps. Take care.
What all is compatable with EM4001?
♫I Bought It On eBaY♫
