Sheilding photo resistors
I am using three photo resistors to make my robot roam towards a light and was wondering
if anyone had an idea what I could to use to shield them from normal room light. I want to
shield them seperate from each other and the normal room light.
You might have to 'paint' the rear of the photo-resistor with black nail-polish to block light from the rear.
And black electrical tape also can work, though that's much less permanent.
You could use plastic tubing as well, but some plastic tubing that appears opaque is not completely so, particularly to infrared. Check first.
Combinations, like of clear plastic tubing with electrical tape on the outside or black shrink wrap tubing on the outside could also work.
tape on it.
The singularity is close at hand, Genetics, Nanotechnology, Robotics...and I get to be alive to see it.
