BigTroubles with Servo-control and PropStickUSB — Parallax Forums
nomadnomad Posts: 276
edited 2007-02-09 22:18 in Propeller 1
hi everbody,
excuses if I irritate again, so:
the simpleServo3.spin program (lookat simpleServoStick1.zip) works with the Propeller-Demo-Board perfectly with 2 micro-buttons.
But, I want control the servos with the PropellerStickUSB pursue. I have cabled the PropStick on a laborCard.
look at servoTestBoard.jpg.
if i use the Stick and simpleServoStick1.spin
Result: The Servo does not run.smhair.gif
mine distributor could not helpsmhair.gif me by telephone. if everything has tried out
No effect.
if somebody maybe have a idea: Run 1 Servo with 2-Control-Button with the
PropStick and a my Spin-Program.
I have properly despaired, now the big Servos for my project are there,
and running with the DemoBoard and the simpleServo3.spin.
would be around every help gladly
hardware info's or source-code
Please help
Greetings
nomad
    edited 2007-02-09 17:16
    The servo ground and the PropStick ground have to be connected together and it's not clear from your schematic if that is so.
  • HenrikHenrik Posts: 10
    edited 2007-02-09 17:57
    You should check what You have connected to pin 12 and pin 32 - according to Your scheme you feed 6-9 volt to pin 12 and 3.3 v to pin 32. Shouldn't it be 3.3 v to both? Or even just to one of them. Are your ground connections connected to a 'common' ground?
    Henrik
  • T ChapT Chap Posts: 4,260
    edited 2007-02-09 18:26
    On the switches, if those are in fact SPDT, then it is not clear what is the wiper position. I would look at it quickly and think you have 3.3V connected straight to GND in one position.
  • nomadnomad Posts: 276
    edited 2007-02-09 19:31
    hi
    thanks for your answer.
    please excuse my fault.
    the new as new attachment: servoTestBoard_NEW.jpg
    greetings
    nomad
    730 x 470 - 67K
    edited 2007-02-09 19:52
    hi everbody,
    excuse my second fault
    now the right one
    greetings
    nomad
    730 x 470 - 67K
  • HarleyHarley Posts: 997
    edited 2007-02-09 20:14
    nomad,
    Still not quite right, IMHO. (look at what figure we see of your schematic)
    P01 - has extra bends; just not asthetic.
    pins 9, 10 - not really connected to Gnd.
    pin 11 - RESn s/b connected to downloader circuitry.
    pin 12 - s/b 3.3v, no?
    Possibly not all accounted for, but hopefully gets you closer to a complete schematic.
    Of course, this is again, my opinion.
    Harley Shanko
    h.a.s. designn
  • Stan671Stan671 Posts: 103
    This is the PropStick USB, so it has the 3.3 V regulator on board and will accept 5-9 volts in on Vin (Pin 12) and generate 3.3 v at 400 ma for use elsewhere on VDD (Pin 32).· All of the EEPROM,·crystal oscillator, USB interface, etc is already on the clip.· Very nice product, I must say!
    Stan Dobrowski
