Line Follower Help................................
I have the line follower module (QTI Sensors).................but i found tht the robot traverses thru a jerky motion.............................so i just came· across this link
http://members.jcom.home.ne.jp/felm/ltc5.mpg
the line follower here is tooooooooo gud............can any 1 help me out in makin such a thing.................
the following link ...................can giv u more info.........
http://elm-chan.org/works/ltc/report.html
plz...................any 1 out ther.....................help me..............................
First - if you are using only one sensor on each side of the line it will get jerky. To overcome this use another sensor closer to the outside of the robot. What this allows for is the first sensor to cross the line and make a small correction and if the second sensor crosses the line make a bigger correction. The more sensors you use the less jerky the movments.
Second - if you can't do the first suggestion try changing how much of a direction change occurs and how fast it happens.
Third - if you are using a servo for steering govern it by a ration instead of a straight turn setting. If you are using motors shorten the time they are on based on a variable setting. This means a smoother turn when a turn occurs. If you don't like those results have it move in small increments.
