Using Shift-Out from SX28 to Shift-In on SX48
Hi Guys
PLEASE HELP!!!
I am trying to pass a byte from an SX28 to an SX48 development board using the Shift-Out and Shift-In commands. I can’t get it to work.
What am I doing wrong…
From>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
DEVICE········· SX28, OSC4MHZ, TURBO, STACKX, OPTIONX
FREQ··········· 4_000_000
Dpin·········· VAR···· RA.0·········· ' shift data
Cpin·········· VAR···· RA.1·········· ' shift clock
Latch········· VAR···· RA.2·········· ' latch outputs
LED······ ··· ·VAR· RB.0
temp1········· VAR···· Byte
ShiftChar····· VAR···· Byte
watch counter, 8, udec
· PROGRAM Start
' Subroutine Declarations
ShiftItOut········· SUB···· 1········ ' pass value out
Start:
ShiftChar = 123
TRIS_B = %00000000
Main:
··· ShiftItout ShiftChar ···' transfer data
break··································
···· toggle LED
···· pause 20
GOTO main
ShiftItout:
· temp1 = __PARAM1····· ··········' capture value
· SHIFTOUT Dpin, Cpin, 0, temp1·· ' send the bits
· PULSOUT Latch, 2·············· ·' transfer to outputs
· RETURN
To>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
DEVICE········· SX48, OSC4MHZ,
Dpin··········· VAR···· RA.1····· ' shift data
Cpin··········· VAR···· RA.2····· ' shift clock
Latch·········· VAR···· RA.3····· ' latch outputs
temp1·········· VAR···· Byte
watch temp1, 8, udec
· PROGRAM Start
Start:
TRIS_A = %11111111
Main:
SHIFTIN DPin, CPin, 0, temp1
GOTO main
PLEASE HELP!!!
· PROGRAM Start
Start:
ShiftChar = 123
TRIS_B = %00000000
Main:
···· toggle LED
···· pause 20
GOTO main
ShiftItout:
· RETURN
· PROGRAM Start
Start:
TRIS_A = %11111111
Main:
GOTO main
not generate the clock. The clock is generated by the shiftOut.
The SX/B shiftIn is only master. You probably need a VP written in assembly,
but perhaps someone has a SX/B version of a SPI slave.
Go to
http://www.sxlist.com/techref/ubicom/virtperf.htm
and scroll down to SX to SX spi interface
regards peter
So my options seem to be:
- Get a slave spi or write one (I'm not keen to write one, i also only work in SX/B)
- Use a UART (seems overkill for 1 byte)
- Write my own proprietry shift register
Kind regards from the Dark Continent
John Bond
Just send the value using SEROUT and SERIN instead of SHIFTOUT and SHIFTIN.
Bean.
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
- That also means wne the system expands, I can have a single sender and many receivers and use 2 bytes, 1 to identify the address and the 2nd as the control byte...
You know, I am fast asleep today.
John Bond
