BASIC Stamp and rotary encoder
I am trying to use a quadrature rotary encoder to determine how far a toy car has traveled, and this information will pass to the microcontroller.
As far as i know from research, a rotary encoder will output pulses. Can someone give me some advices about what kind of BASIC Stamp microcontroller I can use? i was think about the BS1, is that good?
also, does anyone know what kind of rotary encoder is the best for this application? i want to be able to install the encoder on the wheels of the encoder.
Where can i buy these parts please?
thanks all in advance.
To figure this out the easy way mark your tire on the flood with a grease pencil so that the mark on the tire and the floor are in a straight line. Set your program to go ONLY one cog and then mark the tire and floor again.
If you are using something like a hall sensor and get only one reading per revoulution then do the samething but set the program to read one count.
Measure the distance between the marks on the floor and thats how far you robot travels per cog or per revolution.
Count the number of cogs or revoulutions and multiply by distance and you know how far a cog travels or how far one revoultion takes you.
For my robot each cog is about 1/2 inch of travel so the results are simply cogs x distance traveled. This robot uses a BS2.
·· email me parravision@yahoo.com·
