Is there a "right" way to remove a basic stamp from the board?
Hello, I just ordered a new BS2pe to replace my current BS2, and I'm ready to hook it up to my board of education. Unfortunately, I'm having a tough time getting the BS2 out! I certainly don't want to break it, but it's stuck in there really well. Anybody have any tricks for removing these buggers?
You are the only that will appreciate this: I learned to R&R chips when I was co-opted one night to swap out about 150 PROMs in some SMC ARCNet cards.
This was not yesterday.
--Bill
You are what you write.
My ARCNet experience goes way back before SMC's relationship with it. I also learned to pry out EPROMS, kept a whole box of 'em with a UV erasing light as the lid. When you went through all of them, it was time for lunch (or supper) while they were erased to use again.
Compared to you, I am an ARCNet newbie.
However, we built parallel port·networks based on Vector Graphics machines which were HIGHLY cost-effective and off-loaded the mainframe a TREMENDOUS amount, thereby decreasing turnaround time .·. . sometimes from a week to a few seconds.
Before that, we built serial port networks based on Socrates machines. (Do you remember them?) They were not really effective, however they WERE useable. This was in 1978.
--Bill
Take one of those and bend the end to a 90degree angle where it narrows down to fit into a slot in the case.
If you're worried about damaging a chip, or your BS2, just wrap a turn of electrical tape around the tip.
Don't visit my new website...
Of course, you can buy an expensive IC tool, but Benj. Franklin was right on.
Above all - go slow - I have had to remove pins from dead, smoldering ICs and solder them to the corner pins of my older BasicStamps due to careless impatience. But that is another story.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
i bent a pin on a stamp to 90 degrees taking it out
i used a solder iron to soften the metal and bent i back
do this slowly
very scary
japer
Tim
lets see what this does... KA BOOM (note to self do not cross red and black)
It also works well to make sure no pins get bent (if you were to lift the chip out with a screwdriver or wooden flat tip device).
I can't say enough·- it works very well for the $7 investment. No problems with my BS2 and BS2px chips from project to project.
I payed like 5 bucks for it, but after snapping the legs of 2 different IC's with the screw driver method I thought it was a good idea. It is what they are designed for, and work well for.
The singularity is close at hand, Genetics, Nanotechnology, Robotics...and I get to be alive to see it.
Does it look like this?
http://www-ece.rice.edu/~jdw/figs/ic_puller.jpg
Or this?
http://www.realworldtech.com/includes/images/articles/bios-savior-fig1.jpg
