Propeller Super_Bot
Brian_B
·Prop_bot Super_Bot ready for testing , just got done with·code , pretty crude & motors jumpy (I'm going to work on getting Beau's ramping code·installed) Heres my code & a link to pictures ,I'll· try to get one of my friends video camera this weekend and post it.
Brian
http://forums.parallax.com/showthread.php?p=626800
Post Edited (Brian Beckius) : 2/9/2007 4:19:08 AM GMT
Brian
The prior post has a GrowBot in front of the super-bot. That's a Parallax relic from 1997, only to be found in the deepest corners of our building. I'm also currently building a larger robot (three-wheeled) for Prop control, using a gas + alternator hybrid configuration. What's the plan for sensors and control?
·Please forgive the controllers hanging out in the middle of no where. Now that I know it work's, it's time to mount all components. the code in the first post does not have to be alterd, it works perfect.
Brian
PS.
Brian
Paul Baker
·· Heres the video
http://www.youtube.com/watch?v=CeAi22NDznU
Brian
Post Edited (Brian Beckius) : 2/9/2007 10:47:29 PM GMT
motors seemed jumpy on bench test ,must have needed a little load
Brian
http://www.youtube.com/watch?v=SoEX0o4pj5I
post edit : heres the code
Thank's Brian
www.truckwiz.com
·"Imagination is more important than knowledge..." ·· Albert Einstein
Post Edited (Brian Beckius) : 3/11/2007 3:03:23 PM GMT
Heres a photo of my motor, wheel and battery I used on my super_bot , I used a lawnmower wheel with shaft collar slid over it and a hole drilled for the set screw. The 12 volt battery is from electric trailer brakes (it's the break-away battery).
Thank's Brian
www.truckwiz.com
http://www.diycalculator.com/subroutines.shtml· My favorite website ( Bet you can't guess why)
