Comparing variable strings with values from PINK... is it possible? Argh! If so
Hi guys,
This is an excerpt from my program that works:
*********beginning of exerpt
counter VAR Word
NBVAR VAR Byte(3)
SEROUT 13,1021,[noparse][[/noparse]"!NB0R01"]
SERIN 12,1021,[noparse][[/noparse]STR NBVAR\3]
GOSUB l4
DO
MAINIO
IF (NBVAR(1) = "g") THEN
**********end of exerpt
Basically, in this above exerpt, I'm comparing the first letter of the variable from PINK with the letter "g" (as in god) and if it matches, then it will display "god" on the LED array on my PDB. However, I'd like to compare not just the first letter, but the whole 3 byte array from PINK to the whole word "god" to see they match before displaying "god" on the LED array. So, I did the following exerpts that didn't work:
**********beginning of exerpt
counter VAR Word
NBVAR VAR Byte(3)
NBVAR2 VAR Word
NBVAR2 = NBVAR(1) + NBVAR(2) + NBVAR(3)
GOSUB l4
DO
MAINIO
IF (NBVAR2 = "god") THEN
**********The error message was "expected a binary operator or ')'
**********It highlighted the "o" in "god" on the last line of the exerpt when this message was displayed
counter VAR Word
NBVAR VAR Byte(3)
GOSUB l4
DO
MAINIO
IF (NBVAR = "god") THEN
Please help. What I mean by "it works" is that the program can run while attached serially to my PC. However, I still haven't had a chance to test with PINK yet as the router is in my sister's room and she is asleep.... I want to be able to have people type inputs on an online form to communicate with me. However, I want to be alerted instantly whenever someone uses the word "god" or "odd". Thanks.
Lilly.
P.S. Here's the full computer program if you're interested:
' Learning on the PDB - experimental.bs2p
' Spells "dog" on the 7 segment LED display on the PDB as the default.
' Spells "god" on the 7 segment LED display on the PDB when PINK sends the variable into pin 12.
' Spells "odd" on the 7 segment LED display on the PDB when PINK sends the variable into pin 12.
' 7 segment LED display has digits 4, 3, and 2 used on X19.
' 7 segment LED display has segments A through G used on X18. Segment DP is not used.
' Digits 4, 3, and 2 are connected to P5, P4, and P3, respectively.
' Segments A, B, C, D, E, and F are connected to P6, P7, P8, P9, P10, and P11, respectively.
' Segment G is connected to P14.
' {$STAMP BS2p}
' {$PBASIC 2.5}
DEBUG "Program Running!"
counter VAR Word
NBVAR VAR Byte(3)
GOSUB l4
DO
MAINIO
' If button 1 is pressed then display god
FOR counter = 1 TO 330
GOSUB hg
PAUSE 5
GOSUB h4
GOSUB l3
GOSUB lg
GOSUB ho
PAUSE 5
GOSUB h3
GOSUB l2
GOSUB lo
GOSUB hd
PAUSE 5
GOSUB h2
GOSUB l4
GOSUB ld
NEXT
ELSEIF (NBVAR(1) = "o") THEN
' If button 2 is pressed then display odd
GOSUB ho
PAUSE 5
GOSUB h4
GOSUB l3
GOSUB lo
GOSUB hd
PAUSE 5
GOSUB h3
GOSUB l2
GOSUB ld
GOSUB hd
PAUSE 5
GOSUB h2
GOSUB l4
GOSUB ld
NEXT
ELSE
'If no button is pressed then display dog.
GOSUB hd
PAUSE 5
GOSUB h4
GOSUB l3
GOSUB ld
GOSUB ho
PAUSE 5
GOSUB h3
GOSUB l2
GOSUB lo
GOSUB hg
PAUSE 5
GOSUB h2
GOSUB l4
GOSUB lg
ENDIF
LOOP
l4:
MAINIO
LOW 5
RETURN
l3:
MAINIO
LOW 4
RETURN
l2:
MAINIO
LOW 3
RETURN
h4:
MAINIO
HIGH 5
RETURN
h3:
MAINIO
HIGH 4
RETURN
h2:
MAINIO
HIGH 3
RETURN
hd:
MAINIO
HIGH 7
AUXIO
HIGH 14
HIGH 10
HIGH 8
HIGH 9
RETURN
ld:
MAINIO
LOW 7
AUXIO
LOW 14
LOW 10
LOW 8
LOW 9
RETURN
ho:
AUXIO
HIGH 14
HIGH 10
HIGH 8
HIGH 9
RETURN
lo:
AUXIO
LOW 14
LOW 10
LOW 8
LOW 9
RETURN
hg:
MAINIO
HIGH 6
HIGH 7
AUXIO
HIGH 14
HIGH 11
HIGH 8
HIGH 9
RETURN
lg:
MAINIO
LOW 6
LOW 7
AUXIO
LOW 14
LOW 11
LOW 8
LOW 9
RETURN
counter VAR Word
NBVAR VAR Byte(3)
GOSUB l4
DO
MAINIO
counter VAR Word
NBVAR VAR Byte(3)
NBVAR2 VAR Word
GOSUB l4
DO
MAINIO
counter VAR Word
NBVAR VAR Byte(3)
GOSUB l4
DO
MAINIO
Lilly.
' {$STAMP BS2p}
' {$PBASIC 2.5}
counter VAR Word
NBVAR VAR Byte(3)
GOSUB l4
DO
MAINIO
GOSUB hg
PAUSE 5
GOSUB h4
GOSUB l3
GOSUB lg
GOSUB ho
PAUSE 5
GOSUB h3
GOSUB l2
GOSUB lo
GOSUB hd
PAUSE 5
GOSUB h2
GOSUB l4
GOSUB ld
NEXT
GOSUB ho
PAUSE 5
GOSUB h4
GOSUB l3
GOSUB lo
GOSUB hd
PAUSE 5
GOSUB h3
GOSUB l2
GOSUB ld
GOSUB hd
PAUSE 5
GOSUB h2
GOSUB l4
GOSUB ld
NEXT
ELSE
GOSUB hd
PAUSE 5
GOSUB h4
GOSUB l3
GOSUB ld
GOSUB ho
PAUSE 5
GOSUB h3
GOSUB l2
GOSUB lo
GOSUB hg
PAUSE 5
GOSUB h2
GOSUB l4
GOSUB lg
ENDIF
LOOP
l4:
MAINIO
LOW 5
RETURN
l3:
MAINIO
LOW 4
RETURN
l2:
MAINIO
LOW 3
RETURN
h4:
MAINIO
HIGH 5
RETURN
h3:
MAINIO
HIGH 4
RETURN
h2:
MAINIO
HIGH 3
RETURN
hd:
MAINIO
HIGH 7
AUXIO
HIGH 14
HIGH 10
HIGH 8
HIGH 9
RETURN
ld:
MAINIO
LOW 7
AUXIO
LOW 14
LOW 10
LOW 8
LOW 9
RETURN
ho:
AUXIO
HIGH 14
HIGH 10
HIGH 8
HIGH 9
RETURN
lo:
AUXIO
LOW 14
LOW 10
LOW 8
LOW 9
RETURN
hg:
MAINIO
HIGH 6
HIGH 7
AUXIO
HIGH 14
HIGH 11
HIGH 8
HIGH 9
RETURN
lg:
MAINIO
LOW 6
LOW 7
AUXIO
LOW 14
LOW 11
LOW 8
LOW 9
RETURN
Didn't we have a post exactly like this about a week back?
And the first location of an array is offset '0', not '1'. So to look at the first character would be:
IF (NBVar(0) = "g") AND (NBVar(1) = "o") and (NBVar(2) = "d") THEN
END IF
There are no string handling functions on the BASIC Stamp. You can store a string as an array of bytes, but the comparison must be done on a byte by byte basis. The quickest example I can think of that demonstrates this is the example code for the RFID Reader. Please see the link below for the example code. This should help you. Take care.
http://www.parallax.com/detail.asp?product_id=28140
