Variable inputs?
Good days Folks!
I am trying to read each input pin individually without lots of input statements. Can i do it something like this?
i VAR Byte
DO
· AUXIO
· DIRS = %0
· FOR i = 1 TO 10
··· IF INPUT i = 1 THEN DEBUG "Yeah!!!"
··· PAUSE 500
· NEXT
LOOP
This does not work, but can some one suggest something that is similar that does?
Freeing smoke from wire and IC captivity since 1972
i VAR Byte
DO
· AUXIO
· DIRS = %0
· FOR i = 1 TO 10
··· PAUSE 500
· NEXT
LOOP
Also, pins default to input on reset, so unless you are using any of your input pins as an output, the DIRS statement in your code is not necessary.
HTH
Tom, I am well aware of the INx function set, but then it would still require me to have several If--Then--elseif---endif statements to do what I want.
"well, what is it that you want to do?"
I am trying to do bitwise manipulation of another variable base upon the input from the Auxio pins.
I am sending a control word to an LED driver that I have. It'll take a binary byte. If the ith input is high, then I would like the corresponding led to turn on and stay on until the ith input goes low, not before.
···· Initial state of LED driver:···· LED_Driver_Variable = 0000 0000
·····If an input goes high, I need to change just the·bit corresponding to that·LED. I decide to use the dcd function with an if statement.
········· If input 1 = 1 then LED_Driver_Variable = dcd i | LED_Driver_Variable
This allows me to only manipulate the bit I need. Making it a "1" and turning the light on.
Turning it off is a bit more tricky.
········· LED_BasicVariable = dcd i | ~LED_BasicVariable
········· LED_BasicVariable = ~LED_BasicVariable
"Smokey, this is crazy talk!" Nope. Let's go through·an example.
All of the LED's are off.
···· LED_BasicVariable = %0000 0000
Input 3 goes high.
···· LED_BasicVariable = dcd i | LED_BasicVariable
···· LED_BasicVariable = %0000 1000 | %0000 0000
Works good so far, right?
Let's say Input 6 goes high.
···· LED_BasicVariable· = %0100 0000 | %0000 1000
···· LED_BasicVariable = %0100 1000
Still works well? Yep.
Now Lets say Input·3 goes low again. the first stage in turning it off is:
·····LED_BasicVariable = %0000 1000 | %1011 0111
···· LED_BasicVariable = %1011 1111
The second stage is simply a "NOT " call:
···· LED_BasicVariable = %0100 0000
Yeah!!!! IT works as intended.
Ok, so in a formal program, I would be required to write a bunch of IF-THEN statements like
If IN1 = 1 then
else
endif
If IN2 = 1... For all 16 inputs. I would like to not to write that cluncky code.
Thefore, I would like to write statements like:
if input i = 1 then...
And have the micro read "input i" as "input 5" for a high reading on the X4 pin.
Any ideas?
There is a reason.
Really, I am working with 13 I/O's. I communicate with 3 other devices with I2C protocols. I am using the input from some DIP Switches (the part of the programs which I need the inputs for) to determine if I an LED will really turn on if one of the sensors says it needs to.
The EE I am working with, created PCA in such a way that, if DIP switch 8 is high, say, then LED 9 should be on and, if DIP switch 9 is on, then LED 11 should be on... It gets a bit more confusing from here.
The board's design is final and I have to solve this in software.
I guess the answer to my question (though not directly answered) is "No. You can not do what you want to as you described in your original post."
I really wish the answer had been different.
You can then 'mask' off the bits of interest, with a %01 value shifted the appropriate number of bits programmatically.
It seems to me this achieves the purpose you have specified. You could even write a subroutine like:
BitToRead VAR NIB
ResultBit VAR BIT
AllBits VAR WORD
MAIN:
BitToRead = 1
GOSUB CheckMainBit
SEROUT 16, 16468, [noparse][[/noparse]"Bit ", HEX BitToRead, "Value: ", HEX ResultBit, 13]
PAUSE 1000 ' So we don't "flood"
GOTO MAIN
CheckMainBit:
MAINIO
AllBits = INS
ResultBit = AllBits & (%1 << BitToRead) >> BitToRead
RETURN
And, you could do main as:
FOR I = 1 to 16
BitToRead = I
GOSUB CheckMainBit
NEXT
CheckIO:
MAINIO
AllBits = INS
Results = 0 ' Clear out previous results
Results.Bit0 = AllBits.Bit0 ' zero to zero
Results.Bit1 = AllBits.Bit3 ' Bit 1 and 2 used for I2C, for instance, so we 'don't care' about those...
Results.Bit2 = AllBits.Bit4 '
Results.Bit3 = AllBits.Bit7 ' Bits 5 and 6 used for SHIFTIN/SHIFTOUT
RETURN
This way, all your 'bit twiddling' would be in a single subroutine -- to be edited should your I/O map ever change. And in a single call and input read you get all the results you want.
First post - Great! Where have you been all my life! Seriously, that's a clever subroutine. I have not used "<<" or ">>" as I thought that I have not had a need for them.
Second Post - This will still create the problem of one line per bit. But I think I can combine the first posts cleverness with my previously posted "bit twiddling" and arrive at what I need.
Thank you for this very cool "bit retrieval" routine. When I am finished, I'll post the code.
