Defining new color palettes
Is there an option to define your own color palette? I'd like to create SMPTE color bars using the PChip, but the existing HYDRA color palettes are a bit off, especially in the yellow range. I'm still scouring The Book for references to this and I haven't sat down and plodded through it, one chapter at a time--I know, I know...do this first, because I'm hoping to deal with this hurdle first.
Kalo
Failure is not the only punishment for laziness; there is also the success of others.
- Jules Renard
Kalo
- Jules Renard
So either your saturation is 0 IRE peak-to-peak or 40 IRE peak-to-peak.
The saturation is always 40 IREs while saturation bit is enabled (-20 IRE / +20 IRE from LUMI center).
Though I'm working on ways to get around this and generate more colors from the chip. (While trying to keep the currect 3bit DAC design).
Really my reason for doing so is because from an artistic viewpoint... The fixed color saturation lacks contrast between vivid and muted tones. (which don't exist in the current palette)
--Andrew Arsenault.
- K
- Jules Renard
I know that I've mannaged so far to get the Propeller to generate saturations of 40 IRE, 80 IRE and 120 IRE.
(120 isn't the most legal value and shouldn't be used).
Really the Propeller could do much more with a better DAC and two COGs.
Here's a good page on test signals.
www.gekco.com/vidprmr.htm
For the color bars it looks like you'll need saturation values of:...
x0 IRE. White
62 IRE. Yellow
88 IRE. Cyan
82 IRE. Green
82 IRE. Magenta
88 IRE. Red
62 IRE. Blue
x0 IRE. Black
--Andrew Arsenault.
I have made a few hardware mods to the propeller to do this stuff, but the thing I like is if you can live with what it can do stock that's pretty cool, once you start adding more hardware to the video stuff then its like you might as well use another chip.
But, definitely use 2 cogs sync'ed and then summing outputs will work for more chroma as long as the phase relationships are the same.
Andre'
50 cents in extra resisters doesn't cost a whole lot.
I'm interested in doing the most with the current 3bit DAC since it's stock on two common boards (Hydra and Demoboard) and since a lot of home brewers made the same thing on their hockups.
I agree with Andre though, I feel that if you start adding extra chips and active components like a RAMDAC. It sort of defeats the purpose of the Propeller and most other embedded microcontrollers. The Propeller was designed to do the most with the least around it.
One thing is for sure... The stock propeller doesn't have the saturation control needed for accurate SMPTE without a trick or two.
--Andrew Arsenault.
So...Andre', what sort of major points would I need to consider to get these cogs synced through the DAC? I assume one cog runs the high bits and the other the low bits. Any major trials in syncing 2 cogs in this way? I haven't done any multiple cog stuff yet, so my ignorance is probably showing.
Andre', I was just looking over the posts before sending this and noticed you actually had 2 suggestions. I'll try them both to see which (or perhaps if a combination) works for this case; to clarify, when you say "...DAC lookup outside...", is this the same as feeding 2 cogs worth of outputs into a DAC?
Thanks guys,
Kalo
- Jules Renard
You can look at Chip's newer VGA drivers which use multiple cogs to get ideas for synchronization, I also know that some of the video drivers written for the Hydra use more than one cog, so there is synchronization within those as well.
Paul Baker
Post Edited (Paul Baker (Parallax)) : 2/8/2007 9:32:25 AM GMT
