Brute Force Vs Elegant Programming... How do I make the elegant version work?
latigerlilly
Hi guys,
I wrote a program for the BS2P40 on the PDB to display "dog" on its 7 segment LED display as a default. When button 1 is pressed, it will display god for 1 second. When button 2 is pressed, it will display odd for 1 second. This first program works, but it is brute force computer programming. When you read it, you'll know what I mean.
The second post here in this thread has a more elegant computer program, but it doesn't work. The default only displays just the letter "d". When button 1 is pressed, it only displays "8" permenantly. When button 2 is pressed, it experiences no change.
How do I make the more elegant computer program work? What did I do wrong?
Also, I thought that a more elegant computer program will use less memory, but I checked and the more elegant version used 24% of the memory while the brute force computer program only used 19% of available memory. It doesn't make sense. I mean, wouldn't typing GOSUB X a million times take more memory than using a simple set of instructions set in EEPROM ?
Thanks a million,
Lilly.
Here is the brute force program that works:
' Learning on the PDB - experimental.bs2p
' Spells "dog" on the 7 segment LED display on the PDB as the default.
' Spells "god" on the 7 segment LED display on the PDB when button 1 connected to RB0 is pressed.
' Spells "odd" on the 7 segment LED display on the PDB when button 2 connected to RB1 is pressed.
' 7 segment LED display has digits 4, 3, and 2 used on X19.
' 7 segment LED display has segments A through G used on X18. Segment DP is not used.
' Digits 4, 3, and 2 are connected to P5, P4, and P3, respectively.
' Segments A, B, C, D, E, and F are connected to P6, P7, P8, P9, P10, and P11, respectively.
' Segment G is connected to P14.
' {$STAMP BS2p}
' {$PBASIC 2.5}
DEBUG "Program Running!"
counter VAR Word
GOSUB l4
DO
MAINIO
IF (IN8 = 0) THEN
' If button 1 is pressed then display god
FOR counter = 1 TO 33
GOSUB hg
PAUSE 5
GOSUB h4
GOSUB l3
GOSUB lg
GOSUB ho
PAUSE 5
GOSUB h3
GOSUB l2
GOSUB lo
GOSUB hd
PAUSE 5
GOSUB h2
GOSUB l4
GOSUB ld
NEXT
ELSEIF (IN9 = 0) THEN
' If button 2 is pressed then display odd
GOSUB ho
PAUSE 5
GOSUB h4
GOSUB l3
GOSUB lo
GOSUB hd
PAUSE 5
GOSUB h3
GOSUB l2
GOSUB ld
GOSUB hd
PAUSE 5
GOSUB h2
GOSUB l4
GOSUB ld
NEXT
ELSE
'If no button is pressed then display dog.
GOSUB hd
PAUSE 5
GOSUB h4
GOSUB l3
GOSUB ld
GOSUB ho
PAUSE 5
GOSUB h3
GOSUB l2
GOSUB lo
GOSUB hg
PAUSE 5
GOSUB h2
GOSUB l4
GOSUB lg
ENDIF
LOOP
' Sets digit 4 of display on vss.
l4:
MAINIO
LOW 5
RETURN
' Sets digit 3 of display on vss.
l3:
MAINIO
LOW 4
RETURN
' Sets digit 2 of display on vss.
l2:
MAINIO
LOW 3
RETURN
' Sets digit 4 of display on vdd.
h4:
MAINIO
HIGH 5
RETURN
' Sets digit 3 of display on vdd.
h3:
MAINIO
HIGH 4
RETURN
'Sets digit 2 of display on vdd.
h2:
MAINIO
HIGH 3
RETURN
' Sets segments of display for the letter d on vdd.
hd:
MAINIO
HIGH 7
AUXIO
HIGH 14
HIGH 10
HIGH 8
HIGH 9
RETURN
' Sets segments of display for the letter d on vss.
ld:
MAINIO
LOW 7
AUXIO
LOW 14
LOW 10
LOW 8
LOW 9
RETURN
' Sets segments of display for the letter o on vdd.
ho:
AUXIO
HIGH 14
HIGH 10
HIGH 8
HIGH 9
RETURN
' Sets segments of display for the letter o on vss.
lo:
AUXIO
LOW 14
LOW 10
LOW 8
LOW 9
RETURN
' Sets segments of display for the letter g on vdd.
hg:
MAINIO
HIGH 6
HIGH 7
AUXIO
HIGH 14
HIGH 11
HIGH 8
HIGH 9
RETURN
' Sets segments of diplay for the letter g on vss.
lg:
MAINIO
LOW 6
LOW 7
AUXIO
LOW 14
LOW 11
LOW 8
LOW 9
RETURN
Pics;
Post Edited (latigerlilly) : 2/5/2007 4:13:19 PM GMT
Thanks a million,
Lilly.
' {$STAMP BS2p}
' {$PBASIC 2.5}
counter VAR Word
GOSUB l4
DO
MAINIO
IF (IN8 = 0) THEN
GOSUB hg
PAUSE 5
GOSUB h4
GOSUB l3
GOSUB lg
GOSUB ho
PAUSE 5
GOSUB h3
GOSUB l2
GOSUB lo
GOSUB hd
PAUSE 5
GOSUB h2
GOSUB l4
GOSUB ld
NEXT
GOSUB ho
PAUSE 5
GOSUB h4
GOSUB l3
GOSUB lo
GOSUB hd
PAUSE 5
GOSUB h3
GOSUB l2
GOSUB ld
GOSUB hd
PAUSE 5
GOSUB h2
GOSUB l4
GOSUB ld
NEXT
ELSE
GOSUB hd
PAUSE 5
GOSUB h4
GOSUB l3
GOSUB ld
GOSUB ho
PAUSE 5
GOSUB h3
GOSUB l2
GOSUB lo
GOSUB hg
PAUSE 5
GOSUB h2
GOSUB l4
GOSUB lg
ENDIF
LOOP
l4:
MAINIO
LOW 5
RETURN
l3:
MAINIO
LOW 4
RETURN
l2:
MAINIO
LOW 3
RETURN
h4:
MAINIO
HIGH 5
RETURN
h3:
MAINIO
HIGH 4
RETURN
h2:
MAINIO
HIGH 3
RETURN
hd:
MAINIO
HIGH 7
AUXIO
HIGH 14
HIGH 10
HIGH 8
HIGH 9
RETURN
ld:
MAINIO
LOW 7
AUXIO
LOW 14
LOW 10
LOW 8
LOW 9
RETURN
ho:
AUXIO
HIGH 14
HIGH 10
HIGH 8
HIGH 9
RETURN
lo:
AUXIO
LOW 14
LOW 10
LOW 8
LOW 9
RETURN
hg:
MAINIO
HIGH 6
HIGH 7
AUXIO
HIGH 14
HIGH 11
HIGH 8
HIGH 9
RETURN
lg:
MAINIO
LOW 6
LOW 7
AUXIO
LOW 14
LOW 11
LOW 8
LOW 9
RETURN
Pics;
' Learning on the PDB - god.bs2p
' {$STAMP BS2p}
' {$PBASIC 2.5}
counter VAR Word
tracker VAR Word
track VAR Word
instruction VAR Byte
counter2 VAR Word
counter3 VAR Word
DATA "Gp83gOp92oDp64dOp83oDp92dDp64dDp83dOp92oGp64g"
GOSUB l4
DO
MAINIO
IF (IN8 = 0) THEN
tracker = 0
tracker = 15
ELSE
' If no button is pressed then display dog
tracker = 30
ENDIF
track = tracker + 14
IF (tracker < 30) THEN
counter2 = 33
ELSE
counter2 = 1
ENDIF
FOR counter = tracker TO track
FOR counter3 = 1 TO counter2
READ tracker, instruction
SELECT instruction
CASE "9": GOSUB h3
CASE "8": GOSUB h4
CASE "6": GOSUB h2
CASE "3": GOSUB l3
CASE "4": GOSUB l4
CASE "2": GOSUB l2
CASE "G": GOSUB hg
CASE "O": GOSUB ho
CASE "D": GOSUB hd
CASE "g": GOSUB lg
CASE "o": GOSUB lo
CASE "d": GOSUB ld
CASE "p": GOSUB p
ENDSELECT
NEXT
NEXT
LOOP
END
l4:
MAINIO
LOW 5
RETURN
l3:
MAINIO
LOW 4
RETURN
l2:
MAINIO
LOW 3
RETURN
h4:
MAINIO
HIGH 5
RETURN
h3:
MAINIO
HIGH 4
RETURN
h2:
MAINIO
HIGH 3
RETURN
hd:
MAINIO
HIGH 7
AUXIO
HIGH 14
HIGH 10
HIGH 8
HIGH 9
RETURN
ld:
MAINIO
LOW 7
AUXIO
LOW 14
LOW 10
LOW 8
LOW 9
RETURN
ho:
AUXIO
HIGH 14
HIGH 10
HIGH 8
HIGH 9
RETURN
lo:
AUXIO
LOW 14
LOW 10
LOW 8
LOW 9
RETURN
hg:
MAINIO
HIGH 6
HIGH 7
AUXIO
HIGH 14
HIGH 11
HIGH 8
HIGH 9
RETURN
lg:
MAINIO
LOW 6
LOW 7
AUXIO
LOW 14
LOW 11
LOW 8
LOW 9
RETURN
p:
PAUSE 5
Post Edited (latigerlilly) : 2/5/2007 8:07:35 AM GMT
What specifically were you trying to achieve with your elegance? One usual goal is "more parameterized" -- where you give a subroutine a "g" and a letter position, and the subroutine displays the letter where you want it -- perhaps by calling more subroutines in the process.
Right now, I can't figure out how your 'brute force' code works, much less your "elegant" version.
http://forums.parallax.com/forums/default.aspx?f=5&m=169907
i see i have some homework to do
its not so easy if i though it was
but you didnt do a dot matrix
so now i try to use your code to make my one code
I am from HOLLAND!!!!!
sorry for my bad english [noparse];)[/noparse]
A dot matrix (what you did) is the same as a LED matrix (what I did). The LEDs are just bigger "dots".
Allanlane5,
I am practicing writing programs that use less memory and are easier to write. That's why I am using subroutines, so that I don't have to write the same set of codes over and over again. I have added better documentation in my code. Please look over it for me.
Thanks guys,
Lilly.
Post Edited (latigerlilly) : 2/5/2007 4:18:28 PM GMT
Now take the example where you have dozens of DEBUG lines spitting out TEXT messages. Now the same program will be much smaller because each DEBUG statement uses memory, but using the same one over and over saves space.
http://ocw.mit.edu/OcwWeb/Electrical-Engineering-and-Computer-Science/6-001Spring-2005/CourseHome/index.htm
Everything you need to do it is freely available online - the development IDE (use DrScheme from PLT), the lecture notes, the book, and if you Google the title, you'll also find a set of video-taped lectures. You won't get academic credit for doing the work, but you will learn a lot.
The singularity is close at hand, Genetics, Nanotechnology, Robotics...and I get to be alive to see it.
