BS2 oem reset button
Hi all,
I already ordered an OEM BS2(parts number 27290). After reading the manual and circuit diagram·that i got from· http://www.parallax.com/detail.asp?product_id=27290 I found that there's no reset button on the board.
I am going to use this module with my own project board.Anybody can help me how am i going to put a reset button on my project board?(Schematic Please)
And also I notice a 10mhz resonator on the board while my boe bot use 4mhz resonator. What's the different between this two?
On my project I will use some relay to replace some switch function without any current goes trough it.
Can I use a solid state relay instead of mechanical relay. What's the different between these two relay?
If i can use solid state relay how am i going to connect it with my BS2.
I hope somebody in this forum can help me with this and also if u can provide me the schematic it would be very much appreciated.
Thanks in advance.
Thanks in advance.
Solid state relays theoretically last forever and throws the switch instantaneously. Mechanical relays have a duty cycle where it may wear out at the end of the cycle (sometimes the cycle is 100K to 1million uses) and the mechanical relay is a bit slower (milliseconds instead of nanoseconds). This is theory only, though. In practice, a mechanical relay that is properly chosen for its task can last just as long as a solid state relay and the delay will not be noticeable if it is properly chosen. For example, you use a relay to turn on the lights. You will not notice that the lights turn on in a nanosecond or a millisecond. Furthermore, you'll never turn the lights on and off more than 1 million times in your lifetime, so in this instance, it doesn't matter which relay you choose.
Shameless plug:
I've answered your question, please answer my question
http://forums.parallax.com/showthread.php?p=630082
