Array in Assembly Works Weird
Team:
I amtrying to sort out an array in assembly, using methods outlines awhile ago in thread
http://forums.parallax.com/forums/default.aspx?f=25&m=148004
I've gotten something to work, but it works only partially and in a fashion that I do not understand.
In the above code, the each LED_n indicates the power level of a different LED. These registers, 7 bits, are to be shifted out as to an LED driver chip (TLC5923) MSB first, starting with LED_15. There is an LED connected to a the 9 pin of the LED driver.
I would have thought the above code would adjust the LED on pin 10, but no. This code adjusts the LED on pin 9. There is something apparently something wrong somewhere but I am stumped. Any ideas would be appreciated.
Jim C
'there is something wrong here. I cannot find it. mov t2, #16 Loop_16 mov zz, #LED_0-1 add zz, t2 ' address of LED_0 - 1 in zz movs yy16, zz ' address of LED_0 - 1 + t2 to yy16 source yy16 mov ShiftVal, 0-0 ' LED_0[noparse][[/noparse]t2] > ShiftVal' shl ShiftVal,#25 ' only lowest 7 bits to be shifted out mov t3, #7 ' t3 is number of bits to shift out' call #shiftBits djnz t2, #Loop_16 '... shiftBits nop Bits rol ShiftVal,#1 wc ' C flag set to Value's original bit 31. muxc outa, SIN ' mux it into SIN pin, and pulse SCLK pin or outa, SCLK ' after Read, then cycle CLK High andn outa, SCLK ' CLK Low djnz t3, #Bits ' loop thru Bits 7 times andn outa, SIN ' Leave SIN low at end of shiftout shiftBits_Ret ret '... LED_0 long %00000000 LED_1 long %00000000 LED_2 long %00000000 LED_3 long %00000000 LED_4 long %00000000 LED_5 long %00000000 LED_6 long %00000000 LED_7 long %00000000 LED_8 long %00000000 LED_9 long %00000000 'this does not turn on LED LED_10 long %00001000 'this turns on LED LED_11 long %00000000 LED_12 long %00000000 LED_13 long %00000000 LED_14 long %00000000 LED_15 long %00000000
Jim C
I not yet started to learn the Propeller assembly but i think that you must declaring each element as byte and not as long or initialize 32 bits not 8 ?
Best regards,
dro
in medio virtus
Thanks for the idea. But I don't think that's it. I am able to manage the 32 bit longs OK. It seems to be in the indirect addressing part (MOVS) of the first loop.
Jim C
Ahh... It all becomes clear. It works now.
In the earlier thread mentioned, you had said "note there's a 1 instruction delay because the Propeller fetches instructions ahead of time." I couldn't figure out what you were talking about, as there is no mention of this being problem in the manual under MOVS. But after banking my head against the wall for an hour without success, and seeing it work with the silly NOP, it all makes sense.
Thanks!
Jim C
