RE: control of a servo with output-pin (3.3volt)
hi,
first excuse my verry bad english.
I build a quadrabod with 3DOF.
the servo is a highTurque-Servo with Ncm 274 (Newton-cenitmeters) and a input voltage of
6.0volts.
now, l am looking for simple device (transistors ???· or Operation-amplifier)
and schematics to control the servo with a PropStick_USB-pin (3.3volt)
outputPin
> [noparse][[/noparse]device]
> [noparse][[/noparse]signal_In Servo]
···························· 5.0volt················· 6.ovolt
Thank you for your help.
greetings
nomad
6.0volts.
outputPin
greetings
nomad
Your English is not less good as mine. Mine is very poor.
Is your servo need 6.0 volt for the power and for the signal line ? OR how y think the servo need 6.0V for power and 5.0v for the signal line ?
In the second case, it's very simple to use a MOSFET transistor.
The BS250 can draw 600mA and work practicaly as a switch.
try this :
outputPIn
> to the Gate of the BS250 (or similar)
+5V or + 6V
> to the Source of the BS250
and the Drain to the signal line of the servo
and maybe a 1K resistor between the Drain and the ground (normaly not necessary)
This must work with just one transistor and no more. The signal at the servo's signal line is high when the outpunPin is low (It's an inverter).
dro
in medio virtus
Post Edited (inservi) : 2/4/2007 3:31:31 PM GMT
thank you for your quick answer.
now i want buy the stuff and then .... testing.
when i have troubles or antother questions.
i come back
greetings
nomad
John R.
Click here to see my Nomad Build Log
thanks for your answer
greetings
nomad
