standard resistance values (logarithmic scale)
Hi· Can· any help me with this question.· What number or what scale do I use to generate the 10% preferred or standard resistor values?
··· jonw
··· jonw
I'm not sure what you mean by a scale or number. I generally use a table like that below for referencing all the various standard resistor values:
http://www.sizes.com/materls/resistorVal.htm
Bruce Bates
<!--StartFragment -->
The logarithmic scale with 12 values is based on 10^(k/12) for values of k from 0 to 11. Those are to be rounded off to the nearest integer. But when you do that, you will find it generates the series 10,12,15,18,22,26,32,38,46,56,68,83. There is a discrepancy in the values in the middle. This is a historical accident, simply a matter of convention. The same discrepancy happens in the 5% resistor series. However, the 1% resistor series is exact and follows the rule 10^(k/96) for k=0 to 95, rounded off to an integer. There are no discrepancies.
Tracy Allen
www.emesystems.com
Tracy Allen
www.emesystems.com
