Encoders! too overwhellming for a basic stamp?
Ok, i have a quadrature encoder, (http://spaceagecontrol.com/s021u.htm) that I am trying to interface with a basic stamp. Using supplied code(from forums.parallax) and derived code I have gotten the encoder to work at slow rates of extension, i.e. .25" a second, maybe up to a half an inch a second. however at faster rates, the stamp doesnt seem to be able to keep count. The encoders output is at 134 lines an inch, this doesn't seem to be coming close to what the stamp should be capable of. Am I missing something? Or could the code be overwhelming it? Below is the code that I am using, I have two inputs, channel A, and B. any suggestions would be greatly appreciated. My target extension speed is roughly 1"/sec. Thanks in advance!
[noparse][[/noparse] I/O Definitions ]
' A Output Connects To P0
' B Output Connects To P1
[noparse][[/noparse] Variables ]
oldBits VAR Nib ' Previous State Of I/O Pins 0 - 3
newBits VAR Nib ' Current State Of I/O Pins 0 - 3
direction VAR Bit ' Direction Encoder Is Turned
counter VAR Word ' Counter (0-255)
temp VAR Word
t VAR Word
[noparse][[/noparse] Initialization ]
OUTS = %0000000000000000 ' Set All Output Pins Low
DIRS = %1111111111111100 ' I/O Pins 0 - 1 Inputs
t=1344
newBits = INA
[noparse][[/noparse] Program Code ]
Main:
DO
newBits = INA ' Get State Of I/O Pins 0 - 3
IF newBits <> oldBits THEN ' Have Bits Changed?
direction = newBits.BIT0 ^ oldBits.BIT1
counter = counter - 1 + (2 * direction)
temp=counter*10 / t ' inch conversion
DEBUG HOME, DEC3 temp ," ", DEC2 ((((counter * 10) // t)*10)/844),"/16" , " ", DEC4 counter ' Show New Counter On DEBUG Screen and 16th of an inch fractions etc
oldBits = newBits ' Update oldBits
ENDIF
LOOP
STOP
temp VAR Word
t VAR Word
t=1344
newBits = INA
Main:
DO
ENDIF
LOOP
STOP
- Stephen
Jeff T.
Have you tried running your program with the DEBUG statement removed? That may speed things up.
With some a couple bucks of simple logic circuits you can use the phase shift to determine direction.
If you are interested in this approach, let me know and I'll dig up a circuit for you.
-Martin
StampPlot - GUI and Plotting, and XBee Wireless Adapters
Southern Illinois University Carbondale, Electronic Systems Technologies
